Any source for this steering column part?
redstone65
Post by redstone65 »
There was a steel strap/clamp sort of thing that was around the steering column thru-firewall bracket on the engine side. From the exploded diagrams it seems to share a part number with the bracket plate itself. Is there a source for the strap/clamp anywhere? Alternatives? Mine was completely rust frozen at the bolt and I had to cut it. I don't think a hose clamp would be quite sufficient. ;)
Here are a couple of pics with arrows to the part I'm talking about:
Dave
‘65 F-100 (240) Former military truck
‘70 F-100 (360) restoring with my son
Busboy
Re: Any source for this steering column part?
Post by Busboy »
I've got one if you need it. 25.00 plus shipping.
1967 F-100 4x4 custom cab.
Ranchero50
Post by Ranchero50 »
You can install a normal bolt and nut once the old nut is ground off.
redstone65
Grinding the bolt head off would have been the absolute right thing to do. But, I'm an idiot:
I tend to take the do-first, think-later approach. :pout:
Dave
redstone65
Busboy wrote:I've got one if you need it. 25.00 plus shipping.
Thanks. I'll let you know if I need it.
Dave
Something like this will probably work. It's part of the whole cold air intake product line. I don't remember if it should be 3" or 4" but this is a google search for 4". https://www.google.com/search?q=4%22+ba ... rc=_&vet=1 Probably get one at your local parts store over in the custom/modified section where they keep the cold air intake parts.
redstone65
Oh, excellent. Thank you!
Dave
jamesdfo
Post by jamesdfo »
Being as this thread goes back almost a month, I'm guessing you have come up with a solution??
But just in case, a SS Band Clamp would probably work, and shouldn't rust on you either:)
https://www.google.ca/search?source=hp& ... -seQhmmeu8
redstone65
That’s a good looking clamp. I actually settled on an exhaust u-bolt style clamp. But that SS one looks better. Thanks for the suggestion.
Dave
