So here is my problem.
This truck is new to me, had it 3 days, going through doing preventive maintenance and came across a headache which I'm sure one of you will consider simple easyTrying to find which rear differential I have.
2000 f250 super duty 7.3 l 4x4, no axle code on door from what I see.... so please correct me if I'm wrong here, rear axle has sterling 10.5, 377 ratio, no ABS front or rear. I read one tag as E409H which I think is limited slip, but would like confirmation so I know if I need LSD additive. Also it says synthetic 5w140 only...I assume that was supposed to read synthetic 75w140.
Just want to do this right 1st time.
Door sticker
This is one tag
This is the other.
Yes I searched......yes I'm confused
