1. Is changing out an (identical) transmission something that can be done by myself with out special tools? I assume by looking at it under the truck, that I will need to disconnect the driveshaft, remove the transmission support cross member, disconnect the linkage arms, disconnect the speedo cable, unbolt the transmission, and pull it out of the bell housing? What I am not familiar with is how the clutch and pressure plate is held in place. Will those parts 'fall' out and down into the access panel at the bottom of the bell housing? Do I need to remove the bell housing during the transmission swap?
2. What gear oil do your recommend using in a Ford 3 speed toploader?
3. Has anyone done this before without a lift, and if so, do you have any suggestions? I would like to try to attempt this myself, so I don't have to take it to a shop and pay lots of $ in labor.
I have been doing all the research I can on Ford 3 speed transmissions. I understand the difference between wide and close ratio gears, bolt patterns on the case, and the RAN/RAT markings on the ID tag. I feel pretty sure I can get another 3 speed almost identical to the one in my truck now.
FYI-The problem that has been occurring with my 3 speed lately is "free wheeling" while in 3rd gear around 35-45 mph. It drives fine up to that point and will randomly fall out of gear(the transmission, not the shifter) and into a 'neutral' position. It made a loud whining noise the other morning when it did this. Sometimes a series of metal clacking/clanking sounds are made too. It is unusual and I have never experienced these symptoms the past 7 years since I've owned this truck. It will reconnect back into gear while coasting down the road. The disconnect that is happening usually is brief, not lasting more than 30 seconds. But I don't want to take my chances and keep driving this truck and wound up getting stranded or broke down somewhere. Truck is at my house and I'd like to fix the problem myself if possible. When I say fix it, I mean at least reinstall another 3 speed that works in the mean time until I get into the original and find out what is wrong. Maybe have the original rebuilt when I have some money saved up at a later time. But I'd really like to keep the '72 roadworthy and driveable this fall/winter if possible. Any advice or suggestions greatly appreciated! Thank you.
