From 2wd to 4wd
- 1972hiboy
Re: From 2wd to 4wd
the easiest thing to do is find a 4x4 chassis, is it a f100 or f250?
- Mike R
Re: From 2wd to 4wd
Bump this.
I have an F250 and I am trying to move to parts less traveled. I need a whole new chass, or a whole new frame? perhaps both? Perhaps neither if I told you I was able to cut and weld?
Theeeeeeere ya go!
In Progress:
'67 F250 Custom Cab Camper Special "Cecil"
In Progress:
Re: From 2wd to 4wd
cant be any worse than doing a solid axle swap on the later ttb and tib trucks
full size linkhttp://www.supermotors.net/getfile/8662 ... 07_351.jpg
Phill
78 Mustang
67 F250ish
2010 F250 Harley Davidson
78 Mustang
67 F250ish
- HIO Silver
Re: From 2wd to 4wd
^^^^ that's not articulation. How about this for articulation?ericevenski wrote:I have a 1970 2wd how hard is it going to be to convert it to 4wd?
It's a very involved project and depends if you have the skills, time, money, and tools: http://www.4wheeloffroad.com/project_tr ... index.html
A three link, Chevy Dana 44, Dodge NP 205, King double-stacked, coil-over shocks.
70 F100 LB 2WD, 360FE, E-Street EFI, TKO-500, 76K original miles.. follow my rebuild: The Lo-Buck Bumpside
71 F250 LB, 2WD, 360FE, T18, PS, PB, D60 with 4.11s
73 F100 SB 4WD, 390FE, NP435, +4 on 35s
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
Re: From 2wd to 4wd
It as hard as you want to make it. Leaf is simple quick and easy. Also technically i went both routs. Did the solid axle swap then a body swap. And if we want to play flex pics coil overs with a link set up will all ways beet leaf. One just cost a hole lot more than another.
Driving up some thing that's almost vertical is a little bit different then a hill.
and lastly body swap rout.
Phill
78 Mustang
67 F250ish
78 Mustang
67 F250ish
- averagef250
Re: From 2wd to 4wd
Leaf spring vehicles can articulate as good as anything else.
http://www.youtube.com/watch?v=4I2myOXCTkY
My '70 was built with the same Willock frame. Works fantastic and you can't touch what it can do with coils. Had the rear tires over the cab roof several times.
- Mike R
Re: From 2wd to 4wd
So it's as simple as swapping the axle, transmission and having the right tools? I have a 67...
Theeeeeeere ya go!
In Progress:
In Progress:
Re: From 2wd to 4wd
The right tools, trans, t-case, axles all ready to go. If you want it done fast have every thing ready to go and waiting. Also the ability to fab is a must if you cant cut and welled don't bother. Here is a link http://www.supermotors.net/registry/17494/60039 to all my sas pics from doing it on my bronco some ideas will transfer over others only apply to 80 to 96 trucks.
Phill
78 Mustang
67 F250ish
78 Mustang
67 F250ish
Re: From 2wd to 4wd
Proud new owner of a 69 F250 2WD. What year 4WD frames will a 69 mount to?
- 1972hiboy
Re: From 2wd to 4wd
67-72 the Easiest way to make it 4x4 is find a trashed 4x4 truck and bolt your body on it.
