But after I got the engine onto the chassis, I realized the drain plug just won't work there. It's located on the passenger side, about 1" forward of the rear of the sump, facing outboard. Even if I could get the plug out, it would dump oil all over the crossmember - not cool.
In this picture you can also see the indented areas on the rear of the pan, these were to clear the car's steering linkage.
Kinda dark, but click on this to blow it up, and you can kinda see the issue.
So I went back to my old 390 that I had in the truck back in high school, and sure enough, it's drain plug was different. It's on the driver's side, at the rear corner of the sump, facing outboard and aft. Much better.
So I pulled the pan off the old motor and glass beaded it, and painted it up. As you can see it's part number is C7AE-6675A, with a date code of 08-10-72. I knew the old 390 was not original in my '69, which came with a 360.
I also ordered a Fumoto F-101N drain plug (with the nipple for attaching a short hose). Hopefully this will help solve any oil drain issues I would've had.
http://www.amazon.com/gp/product/B003VC ... 00_details
Have any of you other guys ran into this?? Any performance differences with switching the pans? (I noticed they have different style baffles in them) I'm not building a race truck, so I doubt I'll care...
