I would like to know what size the bolts are that bolt the outside trim panel to the tailgate, on any 68 thru 72 ford pickup.
Thanks Mike
Tailgate
- 67F250CS
re: Tailgate
I dont think they are bolts at all. If you look at back side of the tailgate, you should see small screwheads. These are hard to get out some times so be prepared to grind a couple off. But they are usually standard flat-tip or phillips head screws.
1967 F250 Camper Special
10MPG with key off, in neutral and going downhill!
- granitestate68
re: Tailgate
Hi Mike,
I removed an outer trim panel from mine a little bit ago and the bottom trim piece had the bolts attached with a 7/16 inch nut. The trim panel itself was held in with rivets. Drilled them out.
Lee
Lee
http://www.fordification.com/galleries/ ... p?pos=-550
1996 F250 Slightly lifted 7.3L Diesel
1961 Falcon Ranchero 144 Inline 6
- rjewkes
re: Tailgate
I had to drill mine out
fuelly.com
fuelly.com
