I had my cab off to replace the two front cab mounts (metal) and have the DC rubbert and bolt kit to put it back on with. The heads up on the bolt problems helped be avoiding a big problem.
I am wondering if there is any trick to alignment of the cab to the frame before tighnening the bolts? There is a lot of play built into the system.
CAB to frame alignment.
- frisky
71 f100sb 390/edelbrock everything, 66 F100sb 240ci, 36 flathead pickup, 30 A roadster, Cat D2, Basset Hound Tucker.
- Joshpow
re: CAB to frame alignment.
I dont know of a trick. I always thought you just measure off the frame and get it as close to right as possible, but I hope someone can give us all a trick to help make cab alignment easier.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
http://www.cardomain.com/ride/2972100
71 F-100 Custom SWB
02 F-250 Stroke
- rjewkes
i'm looking to have to replace those as well i plan to mark something if possible. and align it back to there.
fuelly.com
fuelly.com
