new picks.
new picks.
Here is my beast. 72 4x4 360 custom. She is pretty much all stock except the bed is off a 68. It has allot of rust, nothing that cant be fixed!! It runs awesome. need to replace the clutch and exaust manifold gaskets. I have receipts from the early ninghtys and a log book the original owner kept. She has over 325k. I suspect the motor has been rebuilt. Enjoy.......
- heep70
Cool! Wish my engine looked that good. How about an external pic or two?
Greg
1971 F250 "Highboy". SOLD to "Highboy_Firefighter_71"
2000 Subaru Outback limited.
2000 F250 4X4 PSD SuperDuty Crew.
2010 Polaris 800RMK Dragon 155"
2013 Polaris Pro 800 RMK 163"
1980 Built Toyota "Trail Rig".
My last 1971 "Highboy" pics
re: new picks.
hey that excatly how my motor looks but i didnt paint the water pump but i think i might go and take it off right now. my motor dont wanna start up it sits on the side of my house.how do you keep the valve cover clean i washed my engine bay and there are water spots all over the air cleaner housing
1972 ford camper special in progress
re: new picks.
There is supposed to be a cowl gasket, like a door weatherstrip, for the back of the hood. Mine has rotted away. When it rains water sits on my air cleaner too
You can get new ones. I replaced all the gaskets, re: water pump, valve covers and intake to keep oil & coolant form getting blowen all over. Keeps the engine comp. clean. Is your motor a 360? mine is. You also asked me for a diagram for the plug wires, Hope this helps. There are numbers on the intake to match the numbers in the pick.
re: new picks.
yea my motor is a 360 thanks for the picture. now how do i know from where the sparks plugs now. if i paint the water pump is hard to take off.what would i need to take off to get the water pump and paint it my motor is exactly like your the block is black the valve covers are blue i paint the air cleaner. and paint that metal part where the radiator hose hooks up.
re: new picks.
There are numbers on top of the intake manf. next to the valve covers. on the left side it starts front to back...1 2 3 4 on the right side...5678. The numbes the tape on the cap indicates wtat cylinder the wire goes. 1to 1, 2 to 2.
If you are mechanicly inclined the water pump is not real tough to get off. I recomend getting a shop manual for your truck. I bought Detroit Iron shop manual on disk for the puter, its ok, I think I'd rather have the book.
- Big D's 69
I had much rather look at black and white and pictures normally than having to go int hte house and listen the better half complain that I'm dirty and messing up the computer.
1969 Ford F-100. 302 4 barrel, C4 auto, 9in 3.50 open rear, headers, power steering, Turq/wht, Under restoration. In other words, in a million pieces!!!
There is no Replacement for Displacment!!!
My Photo Gallery: http://www.fordification.com/galleries/ ... ?album=655
- binder56jd
re: new picks.
"Sell crazy someplace else. We're all stocked up here" — Jack Nicholson, As Good As it Gets
now serving #235
"the only way to believe in the American dream is to be asleep"--GC
How much easier it is to be critical than to be correct. - Benjamin Disraeli
now serving #235
- CJ,s 67 F100
- 67RED
