window regulators
Zorm
window regulators
Post by Zorm »
Looking for a pair, they don't need to actually function. I'm putting power windows in and am going to modify the regulators with 2 microswitches each for up and down. So it will still look like manual windows, but all you do is move the window handle a little each way to move the window. I can get something like this pre-made but I think I can make them for cheaper.
1971 F250 Camper Special, family owned since 1972
1983 Cherokee, last of the big ones, bought in Italy, family owned since 1998
1965 Corvair Corsa Convertible, 140 engine, 4 speed.
HE guides my path, forgives me when I stray and lights my life
Re: window regulators
Zorm
Post by Zorm »
Yea I saw that but I picked up some after market power window mechanisms for flat windows that mount centered on the window.
Be sure and show us what you do and how you did it. Power windows are a hot topic here. 8) :thup:
Zorm
Post by Zorm »
will do, these were is the discount bin at the Summit up in Ohio when I was there a few years ago, they work, just no switches
Ron_Hall
Post by Ron_Hall »
Zorm wrote:Looking for a pair, they don't need to actually function. I'm putting power windows in and am going to modify the regulators with 2 microswitches each for up and down. So it will still look like manual windows, but all you do is move the window handle a little each way to move the window. I can get something like this pre-made but I think I can make them for cheaper.
Zorm, did you ever find the regulators?
Ron
1971 F100 SWB 390 FE - bored.030 over
Edelbrock Performer - Holley 600 CFI
Stock heads with some porting - Sanderson FF427 Headers
C6 with stock converter - 3.25 rear end gears
One owner...
Zorm
Post by Zorm »
not yet, been sidetracked. Finishing up a home project then back to the truck. I am also assuming the regulators from a 73-76? would work also, bolt up the same?
jzjames
Post by jzjames »
Zorm wrote: assuming the regulators from a 73-76? would work also, bolt up the same?
This would be good to know - I’ll be needing to do mine, down the line.
Ron_Hall
Post by Ron_Hall »
Zorm wrote:not yet, been sidetracked. Finishing up a home project then back to the truck. I am also assuming the regulators from a 73-76? would work also, bolt up the same?
Here is some pics if you want to look at them.
Ron
One owner...
Zorm
Post by Zorm »
Ron_Hall, I would just be using the handle/toothed part. Take that long arm off, mount a two cams on the gear to engage two different micro switches, one up, one down. I'm getting some sealed relay packs from a member on the IFSJA forum to help with window power. Thanks for the pics though.
FLASH 1
Post by FLASH 1 »
73-79 are not the same as the 67's or 68/72's and even all 73/79's are not the same. some trucks the regulators where bolted in < 3 bolts > and others where riveted in the door
Tom, where Ford Trucks Rule
1956 Big Window
1964 F-750 Flat Bed
1965 M-100 Mercury
1966 M-350 Mercury
1966 F350 Wrecker
1972 F-350 Crew Cab
1997 F-450 7.3 with 85,000 original miles
2006 F-150 Crew Cab
2008 F-650 Crew Cab Roll Back 6.7 Cummins
2020 Flat Top Peterbilt Roll Back PX-7 Engine
and 2 cars 1968 XLT and 2017 Mustang
