‘69 f100 clutch equalizer bracket
Looking for some help today. I swapped a straight 6 out for a 351 v8 in my 69 f100. This is my first truck so there has been some learning along the way. I finally have everything bolted in but now realized the engine i put in came out of an automatic and i have a 4 speed. I cant find the engine side equalizer bracket anywhere. Being from Canada there arent any good salvage yards around. Hoping someone here can steer me in the right direction
Re: ‘69 f100 clutch equalizer bracket
There used to be lots of wreckers in your area, but with urban sprawl I'm sure most are gone now, you may need to go north. If not in a rush, I may have one in a few weeks.
I hope you added a pilot bearing to that engines crank, your clutch will not last without it.
F. Noble, Saskatchewan.
Thanks, i gave him a try. No luck on the older f100’scep62 wrote: ↑Tue Mar 28, 2023 7:17 pm![]()
Maybe Jeff's can help ?
https://broncograveyard.com/?gclid=EAIa ... gKu6_D_BwE
New clutch, pressure plate and bearing all installed. Going to try fabricate something but if you do find one please contact me. Ill definitely swap out something OEM for whatever i cone up with in the shopFraser wrote: ↑Wed Mar 29, 2023 6:07 pm There used to be lots of wreckers in your area, but with urban sprawl I'm sure most are gone now, you may need to go north. If not in a rush, I may have one in a few weeks.
