Wheel Spacers
Skkzhg
Wheel Spacers
Post by Skkzhg »
Anyone used wheel spacers to widen the rear track to match the front? If so, brand and/or known issues?
denco555
Re: Wheel Spacers
Post by denco555 »
I used 1.5" spacer on the rear and it looked better. I am trying to find the exact difference in the front and rear axle so I can get a spacer to make them the same width
Re: Wheel Spacers
geradr4
Re: Wheel Spacers
Post by geradr4 »
I know some guys here are running 1.75 spacers. Try to use the search function.
crazyhorse
Re: Wheel Spacers
Post by crazyhorse »
:yt:
It might be a good idea to put both wheels and tires (fully aired up) on the back and let the truck sit down normal on the ground and measure the amount of space between the tire and fender well all the way around , inside & outside of tires on both sides, (consider measuring with truck loaded if you will be hauling heavy loads ) before you purchase the spacers.
The off set of the wheels and the size of the tires can also help determine how thick of a spacer you will need.
Good luck with your choice. :fr:
JoshT
Re: Wheel Spacers
Post by JoshT »
Not sure how well it shows here, but running 2" spacers on the rear. Think it matches up pretty well.
[image]1010[/image]
Hopefully I'll be able to swap to a wider later model rear axle some day.
