Need a manual drum master cylinder
RTG_RACING
Post by RTG_RACING »
Anyone know where to get a master for a manual drum setup on an f100? NPD has one but it's $133. Like to fund something cheaper or can I run a manual disk master?
Re: Need a manual drum master cylinder
Local parts stores still carry them. New for under $50, reman for around $25.
RTG_RACING
I can't find any with the same size chambers on the res. They are all the big/small setup.
Tboggus
Post by Tboggus »
I can give you the NAPA number in the morning.
Busboy
Post by Busboy »
Rock Auto is your friend.
1967 F-100 4x4 custom cab.
RTG_RACING
Napa and rock auto only have the drum/disk units.
Busboy
Post by Busboy »
I've bought 2 of them recently.
Check with your local parts store to cross reference Dorman part number D2UZ-2149-A There are some NOS on Ebay for around $50.
https://rover.ebay.com/rover/0/0/0?mpre ... 2042069679. Howver, I've replaced several using the unequal size reservoirs with no noticeable difference. Part number C8TZ-2140-C https://www.dennis-carpenter.com/en/tru ... r-assembly
Tboggus
Post by Tboggus »
Rock Auto has a ton of the drum only, manual and power. I didn't get to the store today to check NAPA. I will tomorrow, though.
Tboggus
Post by Tboggus »
The only ones I see on NPD with equal sized reservoirs is for F350s not F100s. Could it be that yours was replaced in the past with the wrong one?
Find your year/model on this page, remember the line number and then click on NEXT PAGE in the heading. The same line number will give you the real part number for your original master cylinder. http://www.fordification.com/mpc/sec20/ ... 3-1_04.htm This is supposedly an NOS master cylinder for my 1970 with manual drum brakes.
RTG_RACING
Tboggus wrote:The only ones I see on NPD with equal sized reservoirs is for F350s not F100s. Could it be that yours was replaced in the past with the wrong one?
Well **** you maybe onto something. I guessed it was original since it had a Ford part number. I never thought I could be looking for the wrong part all this time.
