Hey all I have a 72 F250 camper special and need a brake booster and master cylinder I have disc in the front and drum in the rear Do I need to buy a proportioning valve also? I have called LMC truck (only 25 mins from me) and they haven't had them in forever they say. I cannot get anyone to answer me on amazon if theres will fit.... Any help would be great!
Thanks
Need brake booster/Master Cylinder cannot find one
Re: Need brake booster/Master Cylinder cannot find one
Several places sell complete kits or M/C + booster assemblies
Summit has these
https://www.summitracing.com/parts/sum- ... g-block-fe
and these
https://www.summitracing.com/parts/clp- ... ?rrec=true
Your local parts store probably carries the master cylinder although the booster may not be available.
Summit has these
and these
Rock Auto lists several. The booster doesn't care if you have front drum or disc but if you get a combo M/C and booster you may end up with the wrong master. I have found that if you look forward or back a few years on Rock Auto that you will find more options that fit. Be careful with master cylinders. I have found several that claim to be disc/drum that are 1-1/4" that do not work. From what I have found, you need a 1" M/C for the disc/drum combo. Look at 78's for example at Rock. I'll have to look but I may have a virtually new booster in my garage. I'll post again a little later today.
Gary
Littleton, CO
Littleton, CO
The unit I have was purchased for my 1970 F-250. It is a single diaphragm. I bought a dual-diaphragm because it still wouldn't stop and that's when I figured out the M/C piston was too big. The single would probably have worked.
https://www.autozone.com/brakes-and-tra ... 34933_7889
Autozone shows that it will fit a 72. It is yours for the cost of shipping if interested - send me a message.
Are you converting from manual? Are you going drum/drum or disc/drum. The brake distribution block and pressure differential switch and front-brake hold-off may/will differ depending on what you are trying to do.
Gary
Littleton, CO
Littleton, CO
I finally found one at LMC truck Got it home Im going to bench bleed it today and then start the great process of bleeding them to the wheels LOL
Thanks for all of your alls help
Hi, I realize this thread is a little old but I was wondering how your installation went. Did the parts work sufficiently. If so could you share what parts you purchased.
I have not had to deal with this yet, as my truck came from the factory with power disc brakes, and my booster is still working good, but here is someone that bought their booster from CJ Pony parts. He has a 1971 F100, he shows how he installed the booster, and says he is happy with the product from them.
https://youtube.com/watch?v=b8WVP8D02vc
Hope this helps
Hope this helps
