Power washing the underside.
My truck needs a good power wash to get rid of all the build up on the bottom of the engine and trans,I have a power washer but don't want to mess up my driveway-any suggestions on where to get it done?
Re: Power washing the underside.
Back in the early eighties, I bought a couple of Exon Valdez type vehicles, and one of the local Coin Wash places also had a couple oversize bays that they would rent by the hour for guys cleaning their big rigs. A few cans of engine degreaser, a good rain suit, and plenty of paper towels to get clean/dry enough to get back in the interior to drive home after, and Voila! :)
** And if you have a set of metal ramps for doing oil changes, they will come in handy as well, but a floor jack & some jackstands will work as well
James
James
If you use that advice, you may get off as easy as getting kicked off the property, or as bad as a hefty fine depending on location.jamesdfo wrote:Back in the early eighties, I bought a couple of Exon Valdez type vehicles, and one of the local Coin Wash places also had a couple oversize bays that they would rent by the hour for guys cleaning their big rigs. A few cans of engine degreaser, a good rain suit, and plenty of paper towels to get clean/dry enough to get back in the interior to drive home after, and Voila! :)
James
1970 F100 Ranger 2WD
project link: http://www.fordification.com/forum/view ... 22&t=83642
- colnago
Reminds me of the time I ran the "Sea Foam cleaning method" on my 352. I had heard that it could create a bunch of smoke while it soaked off carbon build-up in the engine. My local AutoZone is in the same parking lot as our K-Mart. So, I picked up the bottle of Sea Foam from AutoZone, then drove over to the K-Mart side for the treatment. Sure enough, the neighbors would have hated me if I did it in my driveway!WhitsEnd wrote:If you use that advice, you may get off as easy as getting kicked off the property, or as bad as a hefty fine depending on location.
Joseph
"Sugar", my 1967 Ford F250 2WD Camper Special, 352FE, Ford iron "T" Intake with 1405 Edelbrock, Duraspark II Ignition, C6 transmission, front disc brake conversion.
- Mancar1
- Location: USS Gramps Garage (DD-727) Tehama County, Northern Ca.
Guess I am fortunate to have a place on my own property where I make the mess and then deal with the cleanup.
Can't see making a mess for others to deal with.
Maybe you could lay down a plastic tarp to catch the mess to minimize your driveway cleanup.
Hope you getter clean and keep on Trucking............John
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
I did mine in my driveway. It's gravel but it disappeared fast. I've also done it on the lawn. Grass eats up anything. Did a radiator flush on the lawn too haha.
1972 f100 4x4 4 inch lift with dump box kit-sold
1969 f250 4x4 highboy in progress.
http://www.fordification.com/forum/view ... 22&t=85251
Kyle
Kyle
