I have a 67 f250 4x4, anyone know where I could get push plates for my truck? So sick of shoveling.
Thanks
Snow plow
Snow plow
1967(ish) Ford F250 4X4. 390, NP435, Dana 24, Dana 44 front end closed knuckle 4.11 Drum brake, Dana 60 rear end 3.73 Drum brake
2005 Subaru Forrester XS manual
2009 Scion XB Auto
2009 Scion XB Auto
Re: Snow plow
Probably your best solution is to buy a used plow then adapt it to your truck.
When your truck was new it was pretty much a universal mount that would fit different models.
I've had good luck with the Western brand , the pump, motor and lift ram are one unit with the turn controls built in.
A Monarch brand control unit is also a good choice that will serve any brand plow.
Try to stay away from the pumps that run off of the engine's belts they're slow and a pain in the --- to hook up.
A 7.5 foot plow is a good size , any shorter and you're driving over the spill off from the blade.
Re: Snow plow
Quickest way to kill a truck is to put a plow on it. First the suspension, then the rust.
Seems the perfect excuse to pick up an old 8n or something newer. I use a '58 MF50 and 7' blade. Haven't needed it yet this winter which is a mixed blessing.
Re: Snow plow
Very true ,Thats why I use a designated beater plow truck.Ranchero50 wrote:Quickest way to kill a truck is to put a plow on it.
I've had a '78 and '79 Bronco and gotten about ten years apiece out of them with minimal care.
This year I'm using a '77 short box and I hope I have the age, wisdom and self discipline to get at least 15 years out of it.
I work in a bodyshop and see the results of people plowing snow , it is hard on a truck.
My Dad had an Allis Chalmers B with a plow and I spent a lot of time pushing snow , it was slow and cold.Ranchero50 wrote:Seems the perfect excuse to pick up an old 8n or something
After I bought my first plow truck ( a 71 F100 with , a too narrow , belt drive pump type, plow) he never plowed with the tractor again.
