Im working on a old Cat D8 from the 1950s.
It dropped a intake valve and took out a piston and a cylinder head.
What are the chances of having to replace the main bearings and rod bearings?
OT Anyone know anything about bulldozers
- OldRedFord
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
Re: OT Anyone know anything about bulldozers
Not sure about engines like that, but in my experience with other engines, unless there was some pretty good damage illustrated on the piston, you're probably OK to leave the bottom end alone.
or, money.
or, money.
- My427stang
Well, you'll likely have to replace one rod bearing, but it really depends how it was serviced when it was new. Low RPM wasn't too hard on them, but they also didn't stop much to be serviced.
71 F-100 SB 4x4, 461 FE, Edelbrock Pro-flo 4, 4 speed, 4 inch softride lift, all poly bushings, integral PS, most mods installed since the 80's
70 Mustang Sportsroof 489 FE, EFI, TKO-600 5 speed, 4.11s
Engine building by-appointment only--30+ years, specializing in strong street pump gas FEs
