Painting/Coating the chassis??? Need input
Ducote
Post by Ducote »
Hey everyone, I am trying to get a plan together for starting my frame off restoration. Fist order of business is to get everything torn down. I want to paint/coat the frame. What direction is the best for the long term? I've heard that powder coating is good but chips easily. I've heard rubberizing tends to lift after a while. So what is the best way to go about it?? Thanks!
Re: Painting/Coating the chassis??? Need input
I blasted mine with Black Diamond then 2 coats of POR15 topped off with 2 coats of Eastwood Chassic Black. Eastwood's Rust Encapsulator is also a good sub for POR15.
Ranchero50
Post by Ranchero50 »
What's the budget?
For a restoration, dip it in a vat of waste black paint after chemically removing all the corrosion and crud.
Subzero
Post by Subzero »
I used Eastwood Rust Encapsulator and the Extreme Chassis Black and my 68' frame, suspension, and engine bay. Stuff is pricey for a case of aerosol cans, but the result was great for painting it with the body on the truck (engine was out though). I still removed all the corrosion I could off the frame with a wire brush wheel before painting it. Held up pretty good even in the areas of the frame right next to the headers that I think most paints would burn off. That paint kept the rust away for the remaining 1.5 years I owned it and never tried coming off.
1972 F100 Sport Custom-2WD, Aqua Blue and Wimbleton White, LWB, 302 V8 and C4 trans, P/S, P/B - under construction
Gone but not forgotten: 1968 F100 Ranger- 2WD, LWB, original rebuilt 360 V8, Autolite 2bbl carb, C6 Trans, Hedman Headers, Powermaster Racing Starter, H-Pipe and Glasspacks, P/S, P/B, A/C
67mann
Post by 67mann »
I used Chassis Saver at the beginning and ended up redoing with XO rust :cuss: A lot of good product's to use out there but, if you don't get the scale knocked down all the way..... worthless :2cents:
I've had enough and I'm not alone
http://s267.photobucket.com/albums/ii304/67mann/
hazelnut
Post by hazelnut »
I used Caterpillar equipment paint. Made to bond to surface rust, Just knock off flaky paint and wire brush. Will handle the abuse of heavy equipment, So a frame is no problem.
I painted the frame about 5 years before I started working on the truck, The frame look the same as it did when I was finished painting it.
I used medium/semi gloss black. I have bleed the brakes and had brake fluid get on the paint on the inner fender. Cleaned it up when I was finished a few minutes later, No damage to the paint.
Only downside I have seen is after the first coat you have to lightly sand the surface because the paint digs into the rust to bond. The surface will be a little rough from the paint digging to bond, so a little sanding will give a smooth surface and will last a very long time with 2 more coats.
Cost about $50 a gallon.
ford4x4fun
Post by ford4x4fun »
I set the neighborhood kids loose with power tools. Bought a media blaster and blasted the hard to get to spots. Than had to bring in a welder to fix some prior owner damage. After that was all said and done I used POR15, that was about 4 years ago and still holding good. Like it mentioned, the boring prep work is probably the most important step in all of this. I will try to find some photos of mine.
CNR Radio Instructor
US ARMY Retired
1971 Ford F100 4x4 (390)
2015 Ford F250 Crew Cab 6.7l
