rear disc brake options
farmall1
Post by farmall1 »
Hey guys. I recently picked up a 1978 front end for my 1970 f100 2wd. I plan to install it and wanted to look at doing disc brakes on the rear at the same time. Someone, I don't remember who, told me that the disc brakes from an 8.8 explorer would bolt up to the 9 inch. Does anyone know if this will work? I am looking to do this on a budget (yea, I know that a dirty word!) I am open to any options that might work. Thanks in advance.
Canonman67
Re: rear disc brake options
Post by Canonman67 »
I haven't seen anything about the 8.8 but here's something I was thinking about. http://www.pirate4x4.com/forum/ford/229 ... 934?page=1
There's no provision for a parking brake though.
ultraranger
Post by ultraranger »
Look for a 1980-1983 F100 or 1980-1986 F150/Bronco 9-inch rear end with the 'Torino' large axle bearing flanges. The backing plate bolts will be 3/8" in diameter (as opposed to 1/2" in diameter).
Measure the center to center distance between the upper and lower backing plate bolts. The 'Torino' flange bolts will be 2-inches apart. If the upper and lower backing plate bolts are 2-3/8" apart, it isn't the correct rear end.
With the 'Torino' flange 9-inch rear end, you'll be able to bolt on '95-'01 Explorer rear discs with a couple of spacers and a custom set of 31-spline axles with a 5 x 4.5" lug pattern.
Steve
1969 SWB F100 Ranger. 240-6, C-4, 9" N-case 31-spline Traction-Lok w/3.50 gears.
1968 Mustang. My high school car. Owned since 1982.
2003 Azure Blue Mustang Mach1.
farmall1
Post by farmall1 »
Thanks Guys. I will take all of this under advisement when I get ready to do something.
Big specht
Post by Big specht »
I think the disc brakes off of a crownvic will work on a 9". And they have a built in parking brake too
tnlprt
Post by tnlprt »
81 bronco front rotors
Metric GM calipers
Weld on brackets for the calipers.......typical circle track
No parking brake
Can be done for around 200 bucks
flyboy71
Post by flyboy71 »
These are available as a bolt on while keeping the 5 1/2 bolt circle. I called about them once to find out what discs I would need to buy as replacements and they told me they are Dodge Ram 1500 discs and GM calipers.
http://www.ecihotrodbrakes.com/rear_dis ... sions.html
-Jeff
1971 F-100 240 straight six, 3 on the tree (parted out)
1972 F-100 302 auto trans, pwr steering, pwr brakes (under construction)
"Things are more like they are now than they ever were before" Dwight Eisenhower
