When Installing a Crown Vic IFS and Coyote Motor which Motor Mounts?
Aerocoupe
Post by Aerocoupe »
I have seen a couple of installs with the CV IFS and a 5.0 Coyote motor and the motor mounts get mentioned but not a lot of detail. One guy used the CV motor mounts but had to get an aftermarket oil pan to get the motor to clear the cross member and I believe had to remove mount the oil filter.
Does anyone make motor mount adapter that uses a stock motor mount or aftermarket motor mount to accomplish installing the Coyote motor without having to change the pan and other parts?
I am pretty sure if it comes down to it I can fab something up but I don't want to burn time to do this if there is already a solution out there.
Aerocoupe
Re: When Installing a Crown Vic IFS and Coyote Motor which Motor Mounts?
Post by Aerocoupe »
Just tying threads together in case someone lands on this one doing a search.
http://www.fordification.com/forum/view ... =5&t=87643
Bronco_77
Post by Bronco_77 »
I used the crown Vic mounts on mine had to change the oil pan but everything else worked out great.
[image]508[/image]
68 f100 390 3 speed on the collom G maw gave to me G paw drove in late 70s till late 80s
77 bronco 302 lifted 5.5 with 33s and rears cut
69 Mustang boss 302 clone bought when was 14 sold when was 28 to build house
Aerocoupe
Post by Aerocoupe »
Which pan did you end up using?
Bronco_77
Post by Bronco_77 »
Been awhile but it was a morso for a Fox body I believe.
Twisted_Steel
Post by Twisted_Steel »
Bronco_77,
Where is the rest of the Mustang you got the engine and wheels from?
I really need those wheels on my 2014 Mustang GT!! :wink:
Bronco_77
Post by Bronco_77 »
I actually stuck a set of steel Vic wheels on the mustang and sold what was left of it and stuck the wheels on my truck till I find what I want to run on it. The back ones are nothin but steel belts from a lil fun before I pulled the motor out of the mustang.
Twisted_Steel
Keep me in mind if you find what you're looking for.
I've been tossing the idea around about selling my Mustang. Sure would make the 69 F100 project finally get underway. We shall see
