rear frame gas tank
1970 blues
rear frame gas tank
Post by 1970 blues »
whats the best gas tank to put in 1970 f250 4x4 rear frame and fuel pump for 6 cyl :?
tmgll26
Re: rear frame gas tank
Post by tmgll26 »
If you look there is some people that put a 1970 ford Mustang 22 gal gas tank in between the frame rails in the back
Lee
Post by Lee »
Hi,
There are many options for this project. Depends on how much modification you want to do. I've even read of 35gal Suburban tank used :nono:
I installed a 16gal Poly tank in my 1970 F250 4x4 under the bed, between the frame rails. It was used in 1970 Scouts. Had to relocate 1 cross member between the frame rails. One advantage to this tank is that the float/sending unit is compatible with Ford gas gauges. This tank fills from the side so the filler neck is on the side of the bed. I think the Mustang tank fills from the top.
Lee
Here's that thread on installing the Mustang tank in the rear frame rails.
http://fordification.com/forum/viewtopic.php?t=46022
Another possibility is the '73 to '77-1/2 4WD F250 tank. Those frames were the same with as ours but had the option of a rear frame mount fuel tank.
http://www.fordification.com/tech/fueltank01.htm
