G'day! Click Click when accelerate.
Chico
Post by Chico »
:? Hello. Hoping for a little help.
1971 f-250 with a 428 FE and Dana 60 and C6
When accelerating from a dead stop I get a click click sound also when shifting to reverse I get a single matching click sound. This has just started. All shifts fine and otherwise perfect. If I accelerate very slowly I get no noise.
Mounts? Transmission? Drive?
Thanks.
1971 F-250 428
elgemcdlf
Re: G'day! Click Click when accelerate.
Post by elgemcdlf »
First place I would look is u joints
Ranchero50
Post by Ranchero50 »
Ditto, park it somewhere it won't roll over you and knock it out of gear, then rock the driveshaft looking for movement.
1972hiboy
Post by 1972hiboy »
Agreed start with u-joints. I have had rear ends internally make that noise and the noise resenated up the driveline so if u-joints get ruled out go to the rear end.
Chico
Post by Chico »
Thanks guys. Will do just that. I'll check the u joint then respond.
1971 F-250 428
Chico
Post by Chico »
Hello again.
Did have some play in the middle joint. Replacing tomorrow. Then will see if noise goes.
1971 F-250 428
Chico
Post by Chico »
U joints done and drive shaft is true and straight.
Alas it's still doing the click click. Thought it was gone but came back to haunt me. Albeit a bit less. Transmission mount all good too.
Any other ideas?
1971 F-250 428
AZf100
Post by AZf100 »
I Would check the rear-end, bay be something loose in there. I've chased some weird noises before coming from the rear-end.
"I ain't as good as I once was But I'm as good once as I ever was"
https://photos.google.com/photo/AF1QipM ... mfKhMOFcFj
1971 F100 SWB 302 2WD (Work In Progress)
2010 F250 4X4 6.4 Power Stroke / lariat Black
2020 F150 4X4 3.5 Eco Boost / icon Silver
Chico
Post by Chico »
Backed off idle and no more noise! Hasn't done it since.
1971 F-250 428
ddcrim
Post by ddcrim »
Had a Dodge truck that did the same thing. Had me going on that one. Turned out to be loose transmission mount. Tightened bolts and problem cured.
