Dana 60 HP front axles
I currently have several bump side F250 4x4's that I have been collecting for several years. I have been restoring them a little at a time and drive them often. Over the years I have collected 5 Dana 60 HP front ends out of 78 and 79,s. I have torn down and rebuilt almost all of them. I was planning on putting them into some of my trucks for better braking and just a more heavy duty front end in general. I understand that it is a little bit of work to swap them into the 67-72.s that I have due to driveline angles and crossmember issues. Here is my question.... A guy contacted me today and wants to trade me 2 Dana 60 low pinions out of 76 crewcabs straight across for 2 of my hp,s. Is this a good trade and would I be better off to do a swap with a 60LP instead? Can you find parts for them still since they are one year only? I dropped a 76 44LP with the big hubs into my 72 last year in a couple of hours no problem. That is what got me thinking in this direction. Thanks for the help.
Re: Dana 60 HP front axles
A low pinion front for a high pinion front? Hell that guy is getting an amazing deal, HPs are designed for front axle applications and stronger overall in that application.
If I remember correctly the HP 60 should bolt in pretty easily. I know the 44 of that vintage will bolt in and it wouldn't surprise me if the 60 bolts in as well.
71 3/4 ton 4x4 highboy
68 Mercury Monteray
68 Mercury Monteray
That guy would be getting a great deal. From what I hear the low pinion Dana 60 are hard to find parts for. Other than shortening the driveline the HP Dana 60 is an easy swap. Just my
Doug
Doug
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
Dana 60 hp's here in Utah go for big bucks. $1200 to $1500 not rebuilt.
- averagef250
The ONLY advantage the 76-77 low pinion 60 has over the 76-77 44 front is it has kingpin knuckles. The 76-77 dana 60 is a dana 44 with 60 gears and knuckles, most of the parts are the same as a 76-77 44 front.
My advice is to do the work to fit the HP 60's in your trucks.
- Wes
I wouldn't do the trade myself, I would be installing those D60' hp's in my trucks. I fact if you decide to sell any of those D60 hp's send me a PM maybe we can make a deal.
Wes
http://www.fordification.com/galleries/ ... ?cat=10402
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them
67 F250 High boy
69 Bronco
Thanks for the advice, sounds like keeping the 60HP's would be the better choice. I thought they were all built the same through all the years, but it sounds like the 78-79 are the way to go if you want a stout front end that you can still find parts for. I have not seen a 60LP from the 76 and 77's myself in person to do a comparison. I guess I will keep them for now and maybe drop one in to see how it goes. Thanks again for al the advice and if I sell any of them I will PM the responders first.
- mlheppl
I agree, and I'd also be interested in one of those D60's if you decide to sell.Wes wrote:I wouldn't do the trade myself, I would be installing those D60' hp's in my trucks. I fact if you decide to sell any of those D60 hp's send me a PM maybe we can make a deal.
Mike
71 F250 4X4
99 F250SD 4X4 7.3L PSD
71 F250 4X4
- Redcap
I would tell that guy to go pound sand.
The HP's in ether 44 or 60's are the way to go. I started with a hp 44 until I found a hp60 for $1600. You get better ground clearance bigger and better brakes that are disk, and a lot easier to find parts for. I know on some of those lp60's are drum brakes but I have seen a few with disk brakes to. But I would stay away from the lp60's or at least don't pay to much for one if you try to get one they are not worth a lot of money.
67 Highboy with 427FE 79 dana 60 front dana 70 rear 13" of lift 38" swampers. 72 F100 2wd short bed 302 toploader 4speed. 71 F100 shortbed 4x4 rust bucket. 68 F100 2wd long bed parts truck no rust.
