Adding power brakes
Adding power brakes
okay i was wondering on my 360 if their is a vacuum port for me to add power brake booster and master cylinder on my 2100 carburetor.../?? i saw that O-ryllies has one for 100 bucks that fits all motors from 1968 to 1976 or something like that... then all i have to do is add a vacuum line to the carb and if i dont i will convert to a after maket 4 barr....
that has a second full vacuum port.
1971 f-100 sport custom two wheel drive with 360 auto, restoration
2005 dodge magnum 5.7 hemi all bolt ons and 100 shot of nitrous
400 rwhp on 100 shot
466 rwtq on 100 shot
Re: Adding power brakes
the brake booster vacuum comes directly from the intake manifold. it should be on the passenger side just to the slight rear of the carb. is the main vacuum port. if you have a aftermarket intake you can remove any vacuum plug on the intake on use that port as your vacuum source.
Don't go the above route route!O-ryllies has one for 100 bucks that fits all motors
If you just need the fitting I'm sure that Fordman might have one, if not PM me.
Dang, is that vacuum fitting really that rare?
O sorry im not talking about the fitting being a 100 bucks im talking about the Power brake booster and master cylinder for a 100 bucks.... haha sorry. i prob have it just i have the truck at my mothers house until i can get it going agian.
- 70_F100
Do you have the brackets for mounting the booster to the firewall??71f100anddodgemagnum wrote:O sorry im not talking about the fitting being a 100 bucks im talking about the Power brake booster and master cylinder for a 100 bucks....
I'm about 99.9999999% positive they won't come with the booster/master cylinder from O'Reilly's or any other parts store.
That's not an oil leak
That's SWEAT from all that HORSEPOWER!!
thats what i love about forums.. i though it mounted directly to the fire wall thinks i guess i need to do some more research....
- Redcap
Need brackets, unless going the hydroboost route.
i cant confirm this yet. but i saw one of our trucks with a newer style early 90's booster and master on it. it didnt use the brackets. it was bolted on to the fireewall /brake bracket somehow. i have yet to check it out and confirm how it was done yet.
- 70_F100
I did this to my truck recently, yes you will need the brackets, but you will need the straight pass thru rod brackets, not the z-bar type. All the oreillys are the straight through type boosters. These are alot easier to set up and maintain, so I was happy to go to the junkyard and get the right stuff. The ebay brackets are the right ones, but you will also need the screw in pedal adapter to connect the end of the rod to the pedal, this is also how you adjust them.
