hd44 axle disc brake conversion
- mybros71
I've searched on here and been unable to locate a source of information on changing my front closed knuckle Dana 44HD axle over to disc brakes. It's on a 71 F-250 4wd. 3500#axle with factory drum brakes.
2006 Mustang GT (Wife's)
1962 Comet Custom (Wife's)
1971 F100 2wd Prerunner Project (Daughter's)
1971 F250 4wd "The Beast" (Son's)
2007 Toyota Tundra 4wd. (Credit Union's)
Seriously, the best truck I've ever owned, without exception.
- averagef250
Re: hd44 axle disc brake conversion
Supposedly it's possible with chevy spindles-out, but your miles ahead to swap in a complete 76-79 axle.
- mybros71
I think that's what we're going to end up doing. I just happened to have an open knuckle, 8 lug, Dana 44 with two flat top knuckles. It's out of an early Chevrolet. I wonder if the knuckles will bolt up to a high-pinion FS Bronco housing? I have one of those too. I don't like the thought of down grading the axle weight rating, but I want to have discs up front. Thanks for the info.
Tony
Tony
- Wes
Not sure wether the chevy knuckles will work. The bronco axle needs coil springs and radius arms, your F250 4x4 has leaf springs
Wes
http://www.fordification.com/galleries/ ... ?cat=10402
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them
67 F250 High boy
69 Bronco
- mybros71
I intend on adding the perches for the leaf springs. The axles are both Dana 44s and should have the same ball joint locations. I don't know. It seems like the later model axle is the way to go though. Now to find one some joker hasn't bought up to put under his pavement pounding Silverado.
- averagef250
The DS perch will be right on top of the diff housing. That's why the perch is cast into all the leaf sprung axles.
- mybros71
Adding a perch to the housing is not that difficult. If I can scrounge a later model complete axle, that'd be much less challenging. The problem is, I'm a tight wad and have most of the stuff to use the highpinion. I am going to spend some time to try to find the later model axle so there's less fabrication. If I can't find it or the price isn't right, I'll get to modifyin'. Thanks for the input though. I really appreciate it.
Tony
Tony
69 F250 Factory Crew Hi Boy
64 F100 "Christine"
63 F100 Uni
64 F100 "Christine"
63 F100 Uni
- mybros71
Thanks Garbz. I knew I had heard of such a place, I just couldn't find it.
