1967 F-100 project
Re: 1967 F-100 project
That's an Awsome job you have done I will be keeping a close eye on this one. good luck with the rest of the build
- 67nukeford
Well, finally able to get some time for truck work. I finished up the dolly I'm going to use to work on the cab. I'll bring it home this weekend, hopefully, to replace the front mounts and cab corners. I'm thinking about pulling the cowl also.
- JWW
Great progress!
Did you put any rubber spacers in between your leaf springs when you put them back together? I'm debating on doing that.
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
My project: http://www.fordification.com/forum/view ... &sk=t&sd=a
2004 F150 Crew Cab
- FormerMarine1981
Glad to see you back at it. I think it would be cool to put a dent dash into a bump.
What we do in Life, Echoes in Eternity
- 67nukeford
I think it should work. I did finally get the 89 F-250 that the 351W and ZF-5 5 speed and TC are coming out of this weekend. It was a steal at $550.
- 67nukeford
Yep, got some from the local suspension shop, along with the new clamps.JWW wrote:Great progress!
- JWW
Would you care to take a picture of where you placed the spacers? Thanks
JWW
2004 F150 Crew Cab
2004 F150 Crew Cab
- 67nukeford
I'll do it next time I'm at my brother's place, that's where the frame is at right now. I'll double check my pics, though, and see if maybe I have a close up of the springs.
- Joshpow
Looking good.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
http://www.cardomain.com/ride/2972100
71 F-100 Custom SWB
02 F-250 Stroke
- JWW
If it is no trouble. I appreciate it.67nukeford wrote:I'll do it next time I'm at my brother's place, that's where the frame is at right now. I'll double check my pics, though, and see if maybe I have a close up of the springs.
JWW
2004 F150 Crew Cab
2004 F150 Crew Cab
- 67nukeford
Here are a few pics of the 89 I'm getting the engine/tranny out of. Not sure if I'm going to use that factory EFI, or go to an aftermarket, Depends on how much of a pain it would be to use it, so I'm saving everything off of it for now. The only thing missing off of the motor is the alternator and it's brackets. I'll have to get another one, I want to use that serpentine belt drive.
- 67nukeford
Here is the cab, ready for it's trip to the house. Hopefully get it home Sunday.
- 67mann
I've got an 86 EFI(351W)laying around...maybe it would have been better to use that67nukeford wrote:Here are a few pics of the 89 I'm getting the engine/tranny out of. Not sure if I'm going to use that factory EFI, or go to an aftermarket, Depends on how much of a pain it would be to use it, so I'm saving everything off of it for now. The only thing missing off of the motor is the alternator and it's brackets. I'll have to get another one, I want to use that serpentine belt drive.
Your comin along looks good
I've had enough and I'm not alone
http://s267.photobucket.com/albums/ii304/67mann/
- 67nukeford
I was going to put a 390 in this truck, but since I plan on driving this a lot, I decided to go this route. I have a Super Duty for pulling stuff, and I'm not making a race truck, so the 390 will go in another toy, maybe a Fairlane!
