bumps with lowered altitude!! (lots of great custom bumps!!)
- aramil
Re: bumps with lowerd altitude!! (pics please)
when you flip the rear axle do you experience any bottoming out on the frame? i heard you have to have a c notch for that.
also is it completly neccesary to have the ibeams bent right away or can it wait a while? right now i have no income so what ever i do has to be free.
72, f-100 ranger xlt, 360-c6, 2wd 84k miles.
77, ford f-150 custom 4x4, 400m-c6 SOLD
"the existence of flamethrowers is proof that someone, somewhere, sid to himself, "i want to set those people over there on fire, but i dont feel like walking over there to do it"
I drove mine around with cut springs for a couple years. handles fine. people look at you funny though. the tires last longer than people give credit for as long as your toe-in is set right
dantheman71 wrote:Did some "pic whoring"
Rear shot of above truck
67 that I have seen on youtube, could be a member here
Another prostreet look, this time black
This one I found on a google search, I have seen it before, can't remember where
This truck is from a New Zealand website, it is a sharp looking truck but it has a 350 Chevy engine![]()
I was just wondering if anyone noticed the hood on the green shorty. It has a slope to it.
I've had mine lowered like this since may, its been fine. As long as you take it easy over bumps, You'll be ok. As someone else said, the tires dont wear THAT fast. In fact, I've noticed barely any wear in mine. It took about 2 days to do mine. I will say that the ride is pretty harsh, and im pretty much sittingin my bumpstops in the front. I dont really care though. Mines getting bagged soon.aramil wrote:when you flip the rear axle do you experience any bottoming out on the frame? i heard you have to have a c notch for that.
Ex Ford diesel dealership senior master tech (6 years)
Current bmw level 4 tech.
1972 Ford F100 Stepside - 302, forged TRW flat tops, performer 289 intake, edelbrock 600 cfm carb, CV IFS swap, 4.10 LSD disc 8.8 , AOD 4 speed auto. Currently 5 years in the making.
- Joshpow
About the green truck's hood: I read the article on a magazine's website. It was modified alot. They call it pie cutting. The url is
http://www.classictrucks.com/features/0 ... index.html
It tells alot more about it.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
http://www.cardomain.com/ride/2972100
71 F-100 Custom SWB
02 F-250 Stroke
- td
this truck has lots of extensive custom metal work on it including the hood. EDIT.... oops, joshpow beat me to it
- Joshpow
No problem td. Just jumpy to the keys. I've been gone awhile. You back for long? It'sgood to have you to beat to the draw on info again!!!!
Josh
71 F-100 Custom SWB
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
- aramil
well i might not be joining you guys soon, the guy that had the 20"s called and said only one was five lug even though i seen the whole set... oh well maybe some other time.
- 03rangerxlt
71fordkid wrote:Heres mine, its a 71 with a 68 grille. Stock 302, t-18, 3.07 gears and a mini spool. 2 coils cut (~3'') in front and a spring-under-axle (~5'') in the rear. 205/60's in front and 235/75's in rear.
I like the scallops on the hood. I may (undecided as of yet) do that on my truck (pictured below).
-John
1968 and 2003 Ford Ranger
"Honey, how 'bout I lock you up on charges of aggrevated dumb slut with no future?"
-Det. Ray Carling "Life on Mars"
"Criminals thrive on the indulgence of society's understanding."
i think you should. it would balance better.03rangerxlt wrote:71fordkid wrote:Heres mine, its a 71 with a 68 grille. Stock 302, t-18, 3.07 gears and a mini spool. 2 coils cut (~3'') in front and a spring-under-axle (~5'') in the rear. 205/60's in front and 235/75's in rear.
1967 f100 stepside 300ci I6
1969 f100/600 stepside retro truck -under construction-
1972 longbed trailer
- wt4speed#2
Figured I might as well jump in here(finally got some shots of it I found worthy of this thread). Mine ain't slammed,layin rockers or even in the weeds, but I did it on a zero cost budget and did the work my self. It'll have that rat rod look (hopefully by dec). The front is cut nearly 2 whole coils(still need to get the axles bent). And the rear has the front hanger inversion(the full flip as ezernut calls it)
this was just after the flip with the bed rest there for refernce point(considering moving fenders down an inch or so when I finally get around to doing bed)
before just for reference
actual tape marks showing differnce at the end of the frame rail
And finally several years back when she was driven daily
- ezernut9mm
man, that truck is gonna look badass once it gets done!
wanting to buy a mercury tailgate!
"the man who is swimming against the stream knows the strength of it".- woodrow wilson
Lucky! Stepside bump!!
- ezernut9mm
both of these trucks are members rides.
- 03rangerxlt
So, at about 0500 today, I cracked a beer and added scallops to my hood. I am still split on how I feel about them. I like them, but I am unsure as to if they may be too much. Oh well, like I said, I like them.killakobra wrote:i think you should. it would balance better.03rangerxlt wrote:71fordkid wrote:Heres mine, its a 71 with a 68 grille. Stock 302, t-18, 3.07 gears and a mini spool. 2 coils cut (~3'') in front and a spring-under-axle (~5'') in the rear. 205/60's in front and 235/75's in rear.
me + beer + spray paint = scallops
-John
