Here´s another option...1971ford wrote:bump! anyone know of some good quality cab marker lights?
cab marker lights
- Dr Casti
Re: cab marker lights
1969 Ford F-250 Camper Special. 360 V8, C-4 auto.
- BobbyFord
I believe that no cab lights were factory installed. I believe all were dealer installed. Grote makes quality cab lights; I had some on my '63.
Ford was running the factory wiring for our cab/marker lights them as early as 68:
- BobbyFord
I still don't think cab lights were factory installed. Door mirrors weren't factory installed; they were left inside boxes inside the cab for the dealers to install.
You've given me a mission, I have my '68 and '70 cabs down at the farm with OEM lights still in and I guess if they were factory the holes would be punched, not drilled. I also have a spare set I pulled off the '69 U haul truck and I think those holes were punched, not drilled. Those bulbs are DZ 77-533 with a SAE PC-68 stamp as well. Plastic base with a 1/4" thick black foam gasket that mostly recesses into the light housing.BobbyFord wrote:I still don't think cab lights were factory installed. Door mirrors weren't factory installed; they were left inside boxes inside the cab for the dealers to install.
http://www.ebay.com/itm/dietz-vintage-t ... 5887b45735
i have a favor to ask you all who see this i have a 68 camper special f250 with these cab lights by dietz i was told once before where i could find them but after moving lost the info i have only seen them on two other fords both from the 60s and the other 1 was a semi from late 60s early 70s i would really appreciate any info well i have pics and can get model number from lights lens they are yellow with a concave front not bullit shaped and the stand up not flush with cab for some reason it says my pics are too big for here but i will gladly email to any and all who might help
eBay, they pop up NOS quite often. Usually you can find them in junk yards on larger trucks.
ive been looking for years
Saw these very-retro cab lights in my 'hood.
It's a '67.
It's a '67.
- 1972hiboy
If I recall right those are old international harvester "satelite" marker lamps. I had a set of 5 at one point becasue I was going to do the same thing but lost a couple over the years.
yeah i see those all the time mine are similar but the lens does not go into the housing it is flush and they are bigger and flat on the backside and do not adjust
I installed mine a few weekends ago, still need to wire them up its been to damn hot haha
I came up with what i thought looked good in my head so i drilled the holes
-Mike-
ECV 1849
Build>http://fordification.com/forum/viewtopi ... 22&t=68225
69' F250 Highboy 390ci.,NP435,Dana 24,HPD44,D60
67' Dodge Coronet R/T 440ci.4speed,D60, all numbers correct
72' Dodge Dart 440ci.727,D60,10ptcage street strip on meth 10.40s
05' Chevy Tahoe LT loaded for the wife an the baby duty
12' Ford Focus Titanium Hatch Back, Gas saver for the work week
ECV 1849
