Hey FoMoCoGuy, thanks for replying!
fomocoguy wrote:That sounds much better than my usual method of plopping the engine down on an old tire and ratchet strapping it to the bed rails....
That method probably works OK too!
A particular imaginary scenario always comes to my mind when hauling an engine. What would happen if I needed to make an emergency stop? I can imagine that it would take a serious amount of support to keep the engine from doing some somersaults right in to the back of my skull!
Here's today's update:
With the pressure plate, clutch and flywheel removed I got a better look at the back of the engine, and discovered that in it previous life, this engine block was painted red! It looks like the yellow was sprayed right over the old paint, at least on the back. I'll be very glad to get a good finish on this thing!
And here's the familiar pilot bearing. Any ideas on how to remove it without damaging it? I might not have to remove it for the work Tom's going to do, or I could even just leave it up to him to remove.
I measured the oil pan about a hundred times, then got some 2x8's. I came out with a desired width of around 8 and 3/8", with a depth of 22 and 1/4".
The moment of true discovery.
Here's how the front's looking so far. Notice anything fishy here?
Why yes you probably do! My oil drain plug got a little too "custom" for its own good. Thankfully it slid right in there after I removed the drain plug! I'll have to tape the hole up before taking it for the big drive. That said, I'll need to get it home too, so maybe I need to carve a groove in the wood to clear the drain spout!
And here it rests, all the way in the saddle. To my absolute shock, it seems to be working well so far!!!
On the back you can see how the oil pan brim is digging in to the wood somewhat. I guess that's no big deal!
And a side shot shows that everything lines up OK (I was amazed)!
It looks like a nice, cozy fit!
Next, I'll tie it to the cradle with steel straps!
Thanks for the excellent advice!!!
Robroy
