Big news, and I won't bury the headline: the manifold is in, and it sounds great!
I couldn't have done it without y'all's advice and encouragement! I can't thank everyone from the thread here by name, but you all played a part in my success.
fastEdsel wrote:After the bolts are out I run a thread tap through the bolt holes just real gentle to have a smooth re-assembly.
fastEdsel, that is great advice! I did that on all the holes (well except the ones I drilled out
) and it did make reassembly so much easier - especially on the one with a helicoil. It had been a bear to get that one out, and getting the new bolt in before I ran the tap through made it clear it would be a fight again. Patient work with the tap, and it was a breeze when I did the actual mounting - thanks!
fastEdsel wrote:Use new bolts, flat washers and lock washers and an anti seize on the bolts because there may be a time when you may have to do this all over again, yup been there, done that!
Followed your instructions. As they say, always think about the next guy. Because you ARE the next guy.
After cleaning up the head surface, you could see the damage/pitting to the front port. Also, note the heli-coil from someone's previous pain in the past.
The other ports looked a lot better.
I went with the Remflex gasket - they look quite effective and I have high hopes for its longevity and ability to deal with the pitting.
I used all new stainless steel bolts, and Nord-lock washers for the 6 original bolts. For the two through-bolt/nut holes, I went with 5/16" bolts and standard lock washers. Added some high-temp anti-seize to make it easier next time, and torqued all to the Remflex-suggested 25 lb-ft, starting with the middle bolts and working out from there.
A long journey, but worthwhile.
While attaching the exhaust pipe to the flange it became clear all three exhaust hangers had broken. I hung the pipe temporarily until I figure out the next solution...
