1967 F-100 project
Re: 1967 F-100 project
that does tell me a few things. my 71 has power steeeirng. and it has a 2wd power steering box in it. everything is the same as in your pic except teh power steering box that was added or maybe it was a factory or dealer thing who knows. one thing i seen is how the steering column extension goes out to your box. it is more flat than i thought. mine isnt much higher than yours so that is why it looks like someone torched up my shock tower. is to make spare room for my steering extension. the other thing that is wrong with mine is the pitman arm to linkage is very loose in the pitman arm. i think i am mising some sort of rubber or some kind of gasket between the linkage and the pitman arm. i cant tell but is yours a rubber piece or what kind of material is that. here is a pic of how mine looks right now. oops photbucket is in maintaince mode right now.
- 67nukeford
I'll have to see when I get the pitman arm off. It's on there pretty good, I may have to heat it up to get it off.
- rjewkes
can this be addapted to the F250 4x4 crewcab?67nukeford wrote:Here are a couple of pics, let me know if you need anything else!
fuelly.com
fuelly.com
power steering? do you have pics of your steering box and wheres its located at?
- 67nukeford
Mine is not power steering, although I'm considering adding that.
- rjewkes
Exactly in the same spot with three holes in it for the bolts to go in. no picture of it.
fuelly.com
fuelly.com
theres a bracket on the outside of my frame. the steering box goes in between the frame and the bracket. the bracket is a piece of channel iron. the bolts to hold the pump on go through the bracket box and frame. ill get a better pic later.
- 67nukeford
Well, it's official. I now own FOUR Ford pickups! At least temporarily. I found this 68 in a salvage yard, the cab is in excellent condition. Bought the whole truck for $200. Bed floor is shot, but I'm thinking of cutting off the bedsides to repair my original bed. The motor is an FE, just don't know displacement. I'll check the stroke length when I tear into it.
- 67nukeford
Hey, if you can put up a bigger pic, I'd really like to see how that's set up!
- 67nukeford
Have to remove engine towers and cab mounts, and the frame will be ready for sandblasting and POR-15.
- rjewkes
cool. it's coming along faster than mine, funds are out at the moment.
fuelly.com
fuelly.com
- 67nukeford
Here are some pics of the frame on my homemade rotisserie. Works great! It was just too windy to sandblast, have to wait til the weather settles down.
