390FE (406ci) for #50, built by Tom Lucas at FE Specialties.
Engine Forum Archives
Moderator: Ranchero50
robroy
Re: 390FE (406ci) for #50, built by Tom Lucas at FE Specialties.
Post by robroy »
Good day!
Here's the first part of the interview with Tom Lucas! This part covers the questions that were specific to my engine, while the next part (which I'll post later today) covers many of the general FE questions. EDIT: I've added a transcript of this recording below the video.
Unfortunately, the engine test stand's electric radiator fan makes noise throughout this video, so the audio quality isn't so hot. I'll post a complete narrative of this video later on for folks who might not want to wade through it, since it's not always easy to hear what we're saying.
As before, the WMV file will play almost anywhere while the high quality H.264 (AVI) file will play only on up-to-date computers.
Video: Tom Lucas at FE Specialties Interview, Part A: H.264 (75MB) WMV (69MB)
Note that I created the following video transcript by listening to it with my fallible ears and typing it with my fallible fingers. So I could have made some mistakes. Also, to convey the video content more effectively, I trimmed out some of my one-syllable, passive affirmations like, "Yeah," and various "uh"'s, "oh"'s, and grunts.
Please also note that this forum software includes the word, "wrote," after each quotation, yet Tom didn't write any of this--this is a straight transcript from our spoken conversation.
Begin Video Transcript
Robroy: Hi I'm Robroy, and I'm here with Tom Lucas at FE Specialties in Sacramento.
Tom Lucas at FE Specialties wrote:How you doin'?
Robroy: And I have some questions prepared for Tom about this beautiful 406 FE that he just built for me. So Tom, what are the biggest differences between this design, which you put together, and the design that was in the previous engine that I brought to you?
Tom Lucas at FE Specialties wrote:OK, well, the previous design was a low compression, big cam, unported, intake manifold motor that basically was not a balanced, engineered package for what you're trying to accomplish.
The cam was too big for the compression, the heads had no porting or relieving done, stock valve size, inverted seats, so basically, the motor how it was built wanted to run in the 800 to 3400 RPM range, and the camshaft that was chosen, wanted to run in the 2500 to 6000 RPM range. So you had basically an out of balance motor. So that would be the main difference.
Robroy: OK, great. So um, how would the truck behave with this design, compared to the initial design. Like what differences would you see in this truck, with its wide ratio and all that?
Tom Lucas at FE Specialties wrote:Well with the first motor, it was gonna be a little temperamental off idle, it's gonna hesitate a little bit, you were gonna have to bring RPMs up a little bit, above say eighteen hundred, you know two grand, somewhere in there, to get the engine the engine to be happy.
This motor's designed to be basically just off idle, happy, as soon as you hit the gas. And that will depend somewhat on the carburetor tune as you look in to as you proceed.
So this is a torque motor. The other motor was a stock motor trying to be combined with a hot rod motor and it wasn't. So this was engineered--the way I ported the heads, the size of the porting, the ratio of the runner as it runs in to the bowl area underneath the valve, the fact that we put the bigger valves changed that ratio a little bit, it gave you a little better low lift flow.
I didn't make the ports huge, as you'll see in some of the pictures, but the runner size if fairly constant for torque, that's like the old Ram manifolds of the Mopars, where they had the carbs sitting on either side of the valve cover, and this long Ram manifold, what that was, those were big engines in big, big cars, and they use that long runner length as a tune for torque. It broadened the torque range, it allowed more upper RPM horsepower but it also fed the cylinders well low. So this is similar [to] what I did here--what I do.
So now you have a split duration camshaft that's relatively small on the intake side for idle vacuum, but then you have the same split that's generally found in Cobra Jet cams, which the Ford engineers spent a lot of time figuring out how these motors respond, and that's due to the valve seat angle, this has got a 30 degree intake seat now instead of a 45, so that's a little different for low lift, and there's all sorts of uh, you know I could go on and on about this, but this motor now is built to be efficient from just off idle, up to about five grand--forty eight, five grand.
And because of the porting and the runner freedom, I guess the peak power is supposed to be around 5,200. So the more effective the heads are the more free flowing but small the longer your usable RPM range will be. So, does that make sense?
Robroy: It does, yeah [not true, since it was 95% over my head :) ]. And I think that's what I was after, was a to have it responsive at a wide range of RPMs with that transmission especially since its gears so far apart.
Tom Lucas at FE Specialties wrote:Right, yeah you need--the lower the torque the better. When you drop the gear to the next gear, the motor's not going to be unhappy.
Robroy: Yeah
Tom Lucas at FE Specialties wrote:We like happy motors.
Robroy: So Tom, what advice would you give on timing the engine? What settings would you recommend, and so on?
Tom Lucas at FE Specialties wrote:Well it's timed now.
Robroy: OK
Tom Lucas at FE Specialties wrote:And we had to verify your balancer, and I'll go over that with you, but FEs with stock combustion chambers generally like between 38 and 40 degrees total advance.
So you set the total--that's what you're concerned about with a centrifugal distributor on an MSD, you're worried about your total, not your initial. The initial just plays in to your RPM idle and the transfer slot position. And I think you're pretty close here. But we prefer the Holley carb' because that setup in the Holley is closer to what we like to set the initial timing at but not have the carb be too rich or too lean at that setting in the transfer slot. So the Holley carb does a better job of emulating where the FE wants to idle as far as the calibration of the carb.
Robroy: Oh, OK.
Tom Lucas at FE Specialties wrote:These carburetors [Edelbrock] are basically old AFB Carters that were on Mopars.
Robroy: Oh.
Tom Lucas at FE Specialties wrote:That's what they are. Just FYI.
Robroy: Yeah!
Tom Lucas at FE Specialties wrote:And back in the 70's, everybody took the Carters off and put Holleys on.
Robroy: Oh OK! :lol:
Tom Lucas at FE Specialties wrote:And went faster!
Robroy: Yeah! Well that might be what I wind up doing ultimately.
Tom Lucas at FE Specialties wrote:Well.
Robroy: Possibly
Tom Lucas at FE Specialties wrote:Yeah, they've done, they've actually helped them out quite a bit.
Robroy: Okay, so when I go to play around with the carburetor, do you have any specific advice that I might follow other than the instructions that came with it, for tuning it, and so on?
Tom Lucas at FE Specialties wrote:Well you always want to be leaning on the rich side, and then backing off. Okay, you don't want to lean on the lean side, and detonate the motor, you're at 9-7 to 1, so it's not real--10 to 1 with an iron head is border-line. 9-7 gives you a little leeway with premium gas. But you want to start off a little fat, and then back up a little bit.
Robroy: OK
Tom Lucas at FE Specialties wrote:Okay? And then, if you back up, and it gets faster and then you back up a little more, and it is goes slower, then you want to go back to, that second setting, do you follow me?
Robroy: Yeah
Tom Lucas at FE Specialties wrote:But you want lean on the fat side of the balancing act.
Robroy: Okay
Tom Lucas at FE Specialties wrote:So...
Robroy: 'cause that's the safe side.
Tom Lucas at FE Specialties wrote:You haven't touched it now, right? It's just stock out of the box. And this is richer of the two 750's.
Robroy: Oh, Okay
Tom Lucas at FE Specialties wrote:So, what I would do would be to go up a size on the rods, and the spring is gonna be...that's gonna be how you determine how it drives. You're gonna have to drive it first, and that in the, you know, the spring for the rod raise, determine when that rod raises. And you'll have to drive and load the truck, before you start messing with the spring size.
You might have to go to a jet change, really, you need to have somebody like myself--break the motor in, get some miles on it, and then do a plug read, and see where the motor is, and then plug read each time you do a change.
Robroy: Oh, okay.
Tom Lucas at FE Specialties wrote:Okay, that's the way it's supposed to be done.
Robroy: Yeah
Tom Lucas at FE Specialties wrote:And then the actual best way would be put it on a chassis dyno with an air/fuel mixture ratio and you'll know exactly what to do.
Robroy: Oh, okay
Tom Lucas at FE Specialties wrote:So, maybe what you could do is break the motor in, get around a thousand miles on it, then take it to a chassis dyno--a competent one. We have one up here it's SVS, that I'm real happy with. But they have to use a very high quality wide-band O2 sensor, so that they're measuring what the air/fuel mixture ratio is accurately. And then you can tune that carburetor in different settings: part throttle, part cruise, full throttle, heavy load, you guys can go and do it all at once.
Robroy: Oh.
Tom Lucas at FE Specialties wrote:So, that's really the way it should be done.
Robroy: Okay. So after I run it for what, around a thousand miles, and then I want to have that done?
Tom Lucas at FE Specialties wrote:Yep.
Robroy: Okay, great.
Tom Lucas at FE Specialties wrote:And you're gonna probably find some performance there, so it'll be worth it.
Robroy: Great. So, if I hook a vacuum gauge up to the intake manifold, about how much should I expect to see at idle, when things are operating properly.
Tom Lucas at FE Specialties wrote:Sixteen.
Robroy: About sixteen?
Tom Lucas at FE Specialties wrote:16, would be a good...16, 16 and 1/2, something like that.
Robroy: Okay, So um, how fast can this engine spin before there are any problems--what's it's red line for the tachometer...approximately?
Tom Lucas at FE Specialties wrote:5,800 RPM is where you want to keep this.
Robroy: As long as it's under 58'
Tom Lucas at FE Specialties wrote:Under 58'. This is a hydraulic roller with--I didn't put the real heavy spring in it, so you're gonna want to shift it no later than 58'. But, you're peak power is gonna be around 5,1', 5,200, so there's no reason to really go past 5,5'. See, you're gonna be going down--you can go a little over the peak power,
'cause that will bring your torque up when you change gears. But yeah 5,800 would be your red line.
Robroy: Great. So um, for my temperature gauge, where should I be looking for trouble, like how hot can it get before there's any kind of problem, would you say on this engine? More or less.
Tom Lucas at FE Specialties wrote:Yeah 220. If you see it get above that, you need to pull over and let it cool off.
Robroy: Got it. 220. That I will do.
Tom Lucas at FE Specialties wrote:But, it runs really cool. Every time I put a motor on this test stand I can kinda generally get an idea by how quick it heats up, by how long I've had it running. And this thing is running quite [cool]. So, you shouldn't ever see any issue.
Robroy: Okay. So um, given that it has the high volume pump, and windage tray installed, about how, what kind of oil quantity would you recommend.
Tom Lucas at FE Specialties wrote:It's 5 and 1/2 quarts in the pan, and a quart for the filter. So 6 and 1/2.
Robroy: Okay, would you recommend going beyond that at all, because of, let's see, what was it...the issue we were describing, since you know I'm going to race this, on the uh, on the Leguna Seca, that real twisty track, ya know.
Tom Lucas at FE Specialties wrote: :lol:
Robroy: With a bunch of bails of...big bails of hay in the background
Tom Lucas at FE Specialties wrote:You're gonna chase Ryan--chase Ryan down to Baja.
Robroy: Yeah I'm gonna chase Ryan, with this, uh.
Tom Lucas at FE Specialties wrote:You know, I don't think it would hurt it to go to six quarts total. But here's the deal. You can check, you can put six quarts in it--run the motor, and pull the dipstick out--you shut it off, pull the dipstick out, if you see any bubbles on the end of the dipstick that means that the oil's getting aerated because it's a little too much in there. And you don't want that.
So, but you should be fine, 5 and a half quarts, with that high volume pump, is adequate. You're not gonna be, you know, sticking your left foot out the door going around turns I don't think. I could be wrong.
Robroy: Right foot out the door...
Video Transcript Complete
Thanks very much to Ryan (1971Ford) for operating the camera throughout this interview!
Robroy
robroy
Post by robroy »
Good afternoon!
Here's the second part of Tom's interview, which focuses on general FE questions. Because my video camera ran out of capacity and I forgot to bring an extra DVD for it, I wasn't able to cover all of the questions. Hopefully it will be of interest nonetheless!
Video: Tom Lucas at FE Specialties Interview, Part B: H.264 (83MB) WMV (80MB)
Robroy: I have a few questions that are more general questions about FE motors that aren't specific to this one. The first one is, Tom, what are your favorite and least favorite things about FE engines?
Tom Lucas at FE Specialties wrote:Well they're all good.
Robroy: They're all good!
Tom Lucas at FE Specialties wrote:They're all good.
Robroy: :lol: Okay!
Tom Lucas at FE Specialties wrote:They make a lima bean look sad.
Robroy: All right :lol:
Tom Lucas at FE Specialties wrote:Now you guys know what a lima bean is?
Robroy: No.
Tom Lucas at FE Specialties wrote:Does Ryan know what a lima bean is?
Ryan: No.
Tom Lucas at FE Specialties wrote:Well those 460's were made in Lima, Ohio, so we just changed, instead of "Leema," it's Lima [pronounced like a Lima bean]. So the old back and forth rib getting between the FE crowd and the 385 series as they call them now is, "Ah you just got a lima bean."
Robroy: Oh okay.
Tom Lucas at FE Specialties wrote:But no, they're all good in their own way. FEs are a fantastic design.
The only negative--and it is a big one, but it can be verified--is the fact that it's a thin-wall block casting technology. So it kept the weight of the motor down, but if there was what we call "core shift," when the block was being poured, if the cores for the cylinder bores moved, then we got what we call "core shift" in the block, and one side could be fairly thin and one side could be fairly thick.
You do not get that with a "lima bean." Those are real thick blocks--there's not any issue. But they're real heavy. That 429 block [in Ryan's truck] by itself weights about 300 pounds. This FE block [the Yellow Jacket] weighs about 198 pounds.
But an FE has a shaft-mounted rocker, it's a high ratio so lift under the curve on the cam is way more efficient--it's 175, and it's very stable. It's about a 12 degree I believe, or 14 degree combustion chamber angle to the valve, so the flow on an FE head if it's looked at and worked, is very efficient. It's got a nice long rod from the factory, 6.5" long basically, so the torque is very good from these motors. Now Ford was smart with 429's, they put a 6.6" rod, whereas a big block Chevy has a 6.13" rod, so Ford has way more dwell time and more torque versus the same Chevy.
So the only negative on an FE--well, maybe there's another negative is, in order to change the valve train you gotta take the intake manifold off, or in order to take the intake manifold off you gotta take the valve train off...I guess would be a better way of saying it, so that's a negative. But on a positive side, if you change from a cast iron, boat anchor intake manifold to an aluminum, then you actually are half doing an aluminum head because it's actually part of the head. In other designs this would all be cast iron [pointing to the intake manifold ports] on other engine designs such as the big block Chevy or Ryan's 429. So you put an aluminum intake and you've got kind of a partial aluminum head.
So the only real negative--and then the stock oiling, in its stock configuration, not the 427 blocks, but all the other blocks, was not adequate for high RPM, performance, high horsepower. Whereas some of the other blocks it wasn't as critical, but most factory engines need upgrades in the oil. Okay, it's just a degree of how much. But remember that these [pointing to the Yellow Jacket] started off in Edsels. 332's and they weren't too concerned about, the Edsel going around NASCAR real fast at the time.
Robroy: Okay :lol: Yeah. All right. So Tom what makes the engines you build unusual--what, what parts of the building process are you best at and most proud of? How does it differ from an engine I'd get from another random builder?
Tom Lucas at FE Specialties wrote:Highly blueprinted. Exactly blueprinted to all specs. Piston height, obviously main, rod, cam clearance, ring end gap, piston clearance, cam degree, all that is extremely important here. And that's what makes any two motors run completely different is the blueprinting that's going on.
And then the engine design that we worked out, in other words the part interchanges with the cam, the size of the intake port runner, the compression, the deck height on the piston, that's what sets us apart from most other builders.
Your typical crate engine is just a process motor--and sometimes they get it right--okay, but they're process motor, they cannot put the time in to the motor or else they wouldn't have any profit in the motor. In order to verify all these, and to think about and change--I change all these specs depending on you, the truck, the vehicle, how you're going to use it. And the intake runner length size changes, the degree of the turn in to the intake port changes depending on the vehicle.
So all that design, and then the carb function, the distributor advance, the curve. By the way, your distributor was not curved--you weren't getting total advance 'til 4,600 RPM. So that's been changed. And that could really destroy your fuel mileage on the freeway. You run a centrifugal advance distributor with those heavy springs, you're only going to be sitting at 29, maybe 30 degrees, sucking all sorts of gas because you're retarded and the things heating up on you. So that aspect has to be looked at.
So every aspect of the motor processes have to be thought about and changed and verified. So that is the biggest thing that we do.
And we get our clearances to very exacting tolerances: to ten thousandths of an inch. The crank clearance and the rod and mains is done to ten thousandths of an inch. Not just to thousandths but to--your motor's sitting at '22 on the rod clearance: 0.0022. And I'll change that depending on how many miles the individual's trying to get out of the motor, how much horsepower they want out of it, what time period they want that horsepower out of it. All these things change depending on the usage of the motor.
Robroy: Okay well great. So this is kind of a funny question maybe, but what do you think about using sealed ball bearing, ball bearings instead of those oil impregnated bronze bushings for the pilot in the end of the crankshaft--what do you think about the difference?
Tom Lucas at FE Specialties wrote:They're good.
Robroy: It's an okay thing to do?
Tom Lucas at FE Specialties wrote:Yeah absolutely. Yeah all the factories have done with the small blocks are using a roller bearing, bushing so...it's a bearing now it's not a bushing obviously so. No that's a good thing. They're expensive for FEs. :lol: But no, that's good.
Robroy: Okay. So how 'bout this: um, when people bring an old FE to you, or one that they had build from another shop, what's the most common stuff that you find in the engine that was done incorrectly, or done strangely? What are the most common mistakes people make?
Tom Lucas at FE Specialties wrote:The most universal. Well in a few instances, and actually it's been quite a few, we have taken the pan off to discover that the thrust bearing, the main thrust bearing, was installed in the number five position instead of the number three position that all Fords use.
So, individuals who are used to GM products, where the main thrust bearing goes on number five, decided that this FE should be like a Chevrolet, and they installed the main thrust bearing on number five. And in fact, one individual had a '60 'Bird, and he had about a 140 thousandths crank' end play, which at times would make an incredible knocking noise. So that's been a common problem.
Over-camming, as such in yours, under compression, they'll put an FE around 9:1, which is...a lot of Chevys like 9:1, but FE's don't.
What else; I'm trying to think of stuff that's common that we see. I mean your motor was just a lot of things. And mainly that's what we'll see.
We just did a Shelby motor where the cam was advanced by about nine degrees and it was a small cam. And it was a big cubic inch motor, it was 486 cubic inches, so the torque peak was not...the motor was not efficient. You have all these cubic inches, but then they install a cam that's too small and it's advanced way too much. So that's an issue.
But I don't know if there's really any one boo-boo. If they're not aware of the oiling mods, I have seen that, in a lot of these rebuilds where they'll do performance upgrades to an FE and not do the oiling mods, and then start spinning rod bearings. Because if a machine shop, let's say a stock rebuilder type machine shop, does the machine work on the block, the crank, and the rods, they'll do what they call a mid-spec clearance. So they're gonna put the big-end bore of the block in mid-spec, they're gonna put the crank--and a lot of times, the crank is set on the big side. And I don't know why they do this but they'll cut the crank to the big side. Which in other words, it's not as--you know--the pin's bigger. Whatever: 10, 20, 30...they'll set it to the big side. There's about a thou' up and down clearance for that, and they'll a lot of times set it to the big side.
So what'll end up happening, is if they put everything quote-un-quote to the stock size, you can end up with a half a'thou' clearance on your rod bearing. All right, so somebody gets a new rebuilt motor, and they've done some upgrades like you have done, and they got a half'a'thou' clearance on the rod bearing. Well that clearance allows X amount of oil--oil's a coolant--okay, it's not only expansion factor involved, oil's a coolant, and the amount of clearance that's past that pin is the amount of oil that can flow past it. And X amount of oil is how much heat it can take away from that bearing.
So oil clearance sometimes is misconstrued as just a clearance, but it's actually room for oil, which is a coolant, to take heat off the bearing. The more horsepower you develop the more heat that bearing's gonna see--the more pressure it sees. So hence, you need more oil to cool that bearing and that crank' pin. I mean, it's not rocket science but it all has to equate. Your motor is a little tighter than, 'cause you're more of--you're a higher mileage, so I set it a little bit tighter. You're lookin' more for torque so you weren't going to rob.
Thanks again to Ryan for filming this!
Robroy
This is awesome, I'm feeling a stickie coming up.... :thup:
FreakysFords
Post by FreakysFords »
DuckRyder wrote:This is awesome, I'm feeling a stickie coming up.... :thup:
:yt: :D :D :D :D :D :D :D
Darlin 69 Ranger 390 4v, PS, DS II, disc front, 3G alternator, 67 mirror.
robroy
Post by robroy »
Good afternoon Robert and FreakysFords, thanks for replying!
Excellent, thanks Robert! It's good to know that the videos are entertaining despite not having the best audio quality. I've been researching lapel microphones but haven't ordered any yet; those should make much better recordings in the future.
FreakysFords wrote: :yt: :D :D :D :D :D :D :D
Thanks for your support FreakysFords!
Yesterday Tom handed me some interesting printouts that I wanted to include here!
The first one is the final Dyno 2000 output with mufflers factored in, instead of open exhaust. You can see that the numbers are a little more tame, yet I'm guessing that my exhaust may flow more freely than what Dyno 2000 is expecting. Also, Tom mentioned that the head flow numbers are definitely on the conservative end, but he entered them that way on purpose to make sure the live engine did better than the estimate.
In case you have difficulty reading any of these, you can click on them for a much larger view!
Here's the specification sheet for the custom Diamond pistons!
And the Erson camshaft specification sheet. Tom mentioned that he bought from them because neither Crower nor Comp managed to come up with a proper core for making this camshaft! But Erson has his full confidence, so I suppose it turned out great regardless!
And here's the final invoice. I'm super impressed with how much attention to detail went in to this engine, and appreciate this comprehensive invoice!
Robert and FreakysFords, thanks again for your excellent replies!
Robroy
Dragon
Post by Dragon »
That price could shut down the chevy guys on their low cost to build claims. Nice numbers on torque and HP per dollar spent.
Old Fords Rule
Was a Ford Service Tech
71 F250 with Shell Car 390 NP435 Dana 60 3.73s, PS, PB, 750 EC VS Holley Accel Points Eliminator.
98 Volvo S70 2.4T Auto
71 Service manuals Volumes 1,2,3 and 4 So ask away. :)
My Gallery
Spark test
r71f250
Post by r71f250 »
RobRoy,
First off, congrads.... Awesome motor... You are a very patient man and the motor looks awesome and Tom did a great job... One question, I noticed there on the invoice that Tom had put in a sleeve, can you expound reason why? Was it because of damage or casting was getting thin?
Blessings,
Alan
robroy
Post by robroy »
Good afternoon Dragon and Alan, thanks for your excellent replies!
Dragon wrote:That price could shut down the chevy guys on their low cost to build claims. Nice numbers on torque and HP per dollar spent.
Excellent! Considering the amount of attention Tom gave this engine, and all the top quality parts it received, the price seems good!
r71f250 wrote:First off, congrads.... Awesome motor... You are a very patient man and the motor looks awesome and Tom did a great job...
Thanks very much Alan!
r71f250 wrote:One question, I noticed there on the invoice that Tom had put in a sleeve, can you expound reason why? Was it because of damage or casting was getting thin?
Great observation! I heard from Tom that during the boring process, the machinist noticed that cylinder #1 had previously been bored out of alignment with the other cylinders. So it was too crooked to be mended by boring it to the 428 size while maintaining its alignment with the other cylinders! They had to start from scratch with a sleeve on that one.
Dragon and Alan, thanks again for your superb replies!
Robroy
Happy_Camper
Post by Happy_Camper »
Hey Robroy,
I think you missed your calling. You should have a show on Speed. Great job on the interview, and great answers by Tom as well.
Scott
1972 F250 Explorer C/S, 390-2V, Dual exhaust, C6, Goose neck ball in bed
New and improved with Tilt Wheel, Intermittent Wipers, 2005 Bench seat and 5th wheel camper!...
Life is *very* good!
r71f250
Post by r71f250 »
Happy_Camper wrote:Hey Robroy,
agree with you on that call..... :thup: How about.... The Yellow Jacket Performance Show, on the Speed Channel..... :D
Blessings,
ALan
FreakysFords
Now that I have to agree with!
iamthewreckingcrew
Post by iamthewreckingcrew »
You are going to have lots of fun with this new engine. Make sure someone is around to take a picture of the great big smile you get from your first test drive. :)
68 F-100 Short Box 2wd
302/c4/3.50
81 F-100 Long Box 2wd
460/c6/3.00
92 F-150 Lariat 4wd
302/auto couldn't go wrong for $500
robroy
Post by robroy »
Good morning Scott, Alan, FreakysFords, and IAmTheWreckingCrew, thanks for your replies!
Happy_Camper wrote:I think you missed your calling. You should have a show on Speed. Great job on the interview, and great answers by Tom as well.
Thanks Scott! That's nice of you to say.
This won't be the last Tom Lucas interview, since I'll be driving #50 there this Summer for an inspection! And by then, I'll have lapel microphones and the audio quality should be far better. And I'll give Tom more advance notice next time too--this time, I sent him the interview questions on Wednesday afternoon (the video was recorded on Thursday)!
r71f250 wrote:
Happy_Camper wrote:Great job on the interview, and great answers by Tom as well.
Great idea Alan, thanks! I'd love to interview more of the people I hire to build components for #50, but very few people have the confidence and easy going attitude that Tom has. The majority of folks are leery of a photo being taken, to say nothing of a long video-recorded interview!
Tom's the first specialist I've met who was willing to entertain my funny video documentary idea. I think that in addition to be easy going, he's smart enough to realize that publicity is good for his business, and that a man's customers are his best salesmen (by far)!
FreakysFords wrote:Now that I have to agree with!
Thanks FreakysFords!!! I'm really glad you guys enjoyed the videos, and I'll definitely do this again in the future!
iamthewreckingcrew wrote:You are going to have lots of fun with this new engine.
I think you're right! I'm overflowing with curiosity about what it will be like. Since I've never driven anything like this before, I don't know what to expect! But I'm guessing that the truck will feel effortless, like it's never straining to cruise around the surface streets or accelerate on to the freeway.
iamthewreckingcrew wrote:Make sure someone is around to take a picture of the great big smile you get from your first test drive. :)
You can count on a video-recording of the first drive!!! I plan on documenting the entire engine installation process and first drive videos right here in this thread, so there will be plenty of additional updates!
Scott, Alan, FreakysFords, and IAmTheWreckingCrew, thanks again for your fantastic replies!
Robroy
Alvin in AZ
Post by Alvin in AZ »
Wow, those videos kick butt, Robroy! :)
x2 on a new career for you. LOL :)
On the second video, knowing the time was limited and all, the whole time,
I was really hoping my 6303 ball bearing question wouldn't come up. LOL :)
Anyway, Tom, you got a future customer here, thanks to Ryan and Robroy.
(and to some extent, Poop-Formance too ;)
Didn't catch the name of the "dyno-guys up the street" but sounds to me like
it'd be well worth it to have them check it out.
"performance-gain" Heck, longevity-gain and MPG-gain with an investment
like yours would be enough reasons for it, (IMO, but not my money ;).
Bought a wide band O2 sensor and a wide band controller and plan to "do my
own" which will be half-assed compared to what they'll be able to do for you.
Gonna need it for my MAF conversion and want to try it out on my 2100+FE.
"mis-matched parts" I believe would be good words to describe most builders
FEs including the "disaster's" setup.
Alvin in AZ
robroy
Post by robroy »
Good afternoon Alvin, thanks for replying!
Alvin in AZ wrote:Wow, those videos kick butt, Robroy! :)
Thanks very much for saying so Alvin!
Alvin in AZ wrote:On the second video, knowing the time was limited and all, the whole time, I was really hoping my 6303 ball bearing question wouldn't come up. LOL :)
:lol: Oh well it was good to give it a whirl! And there will definitely be a next time (when I return to his shop for an inspection).
Alvin in AZ wrote:Anyway, Tom, you got a future customer here, thanks to Ryan and Robroy. (and to some extent, Poop-Formance too ;)
Excellent!
Alvin in AZ wrote:Didn't catch the name of the "dyno-guys up the street" but sounds to me like it'd be well worth it to have them check it out.
It sounded to me like, "SVS." And a Google Maps search found this shop, which must be the right one: http://svsrnd.com/
Alvin in AZ wrote:"performance-gain" Heck, longevity-gain and MPG-gain with an investment like yours would be enough reasons for it, (IMO, but not my money ;).
Agreed! I was thinking that same thing. As I understand it, running either too rich or too lean are both bad for the engine, and with the type of money I've spent on it, I want to keep it "clean as a whistle."
Alvin in AZ wrote:Bought a wide band O2 sensor and a wide band controller and plan to "do my own" which will be half-assed compared to what they'll be able to do for you. Gonna need it for my MAF conversion and want to try it out on my 2100+FE.
That sounds like an interesting setup you put together!
Alvin in AZ wrote:"mis-matched parts" I believe would be good words to describe most builders FEs including the "disaster's" setup.
Good point!
Thanks again for your excellent reply Alvin!!!
Robroy
