I am still considering different options, and I'm not sure If I want to mount it under the dash or on top, in a pod.
My question is how would I wire in, or find where to buy sensors that would work on my electrical system for voltage, a temp sensor to fit a performer manifold, and the most complicated to me the oil pressure sensor?
The reason I want to do this is because we all like gauges, right?
I have a mechanical oil pressure gauge, with the line coming into the cab. with a 460, it doenst get much under 20 PSI and 460s are known to run that low of pressure under normal conditions FOREVER. But the gauge stopped working after working intermittently for a while...
Thanks in advance
