HI Somebody as a picture of the right down pipe on a fe engine ?Im trying to fit à 2 1/4 pipe on original exhaust manifold pretty tight between transmission and frame ?
Thanks
Right down pipe
Re: Right down pipe
Walker Exhaust sells replacement pipes to the stock manifolds. I bought them to model my new exhaust. Now the whole set is just sitting on the side of the house.
Re: Right down pipe
Car and truck manifolds can be different , maybe look at a different manifold ?
Re: Right down pipe
Thank you both of you
Cep62 is right the manifold on the passeger side is à car manifold it goes down à lot more than the truck manifold. I manage to bend my exhaust pipe enough to pass. pretty close to starter but ok I guess I think I will put some tape for heat shield on pipe
