1968 right rear lower door frame
tg11350
Post by tg11350 »
My 68 F-250 was smacked at the lower rear of the drivers door before I bought it. Hence the lower cab corner door piller frame and the rocker were badly bent. I'm looking for a drivers side lower rear door piller frame. I can repair the inner rocker, the outer rocker, and the cab corner. The lower door frame is a little harder to fab and it would be nice to procure a "weld on". AMD makes this rear panel for a 1973 and Sherman makes one for a '67 lower front but I can't find one for a 67-72 lower rear. Any ideas?
Regards,
Tony
Re: 1968 right rear lower door frame
A picture would help , but if you cant find the part , you might be able to weld a tab on it .
Then pull it into place , grind off the tab and do some body work.
