Brake booster seal
Brake booster seal
Would anyone happen to have the plastic piece that goes between the brake booster and the firewall for a 72? Mine was busted. If not has anyone used anything else as a seal.
Words of wisdom. Dont sweat the petty things and dont pet the sweaty things...
Re: Brake booster seal
If memory serves me correctly no one was reproducing this part, (either bone yard sourced or obsolete parts sourced)?"NC72crew"Would anyone happen to have the plastic piece that goes between the brake booster and the firewall for a 72? Mine was busted. If not has anyone used anything else as a seal.
Try Green Sales to start, (did you try DC yet)?
http://www.greensalescompany.com/
I believe your right. I dont believe there reproduced. I was hoping someone here had an extra one laying around.
Why do you don‘t use a standard rubber Firewall grommet with the right OD? Just punch a hole of the puschrod diameter in it and your done...
1968 Mercury Cougar 302
1968 Ford F250 Camper Special 429
- Wes
I used a a rack and pinion tie rod bellows from for a 91ish escort, cut it for length but I'm sure other models will work. Fit tight on the rod and the fire hole.
Wes
http://www.fordification.com/galleries/ ... ?cat=10402
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them
67 F250 High boy
69 Bronco
