I've been looking online and getting very different answers.
Is there a bleeder valve or not? Do the front wheels have to be off the ground? Or can i just drive it making sharp turns? How many times will i need to crank the wheel back and forth?
My friend is telling me i can bleed it by loosening the intake fitting.
I had the pump off and replaced intake line.
thanks in advance.
How do I bleed the power steering?
Re: How do I bleed the power steering?
I have never done anything except cycle the steering to full lock (and hold a few second) both ways several times and check the fluid level on anything I’ve ever done.
I’d do it wheels on the ground (so its under a load and level).
No need to bleed it, just turn the steering wheel back and forth a few times. I would also suggest using real power steering fluid instead of ATF. It will whine less.
Mine did not like PS fluid at all, back to type F.
.......if it calls for type F use it......I had the same thing happen......DuckRyder wrote:Mine did not like PS fluid at all, back to type F.
"Life is a garden - dig it"...........
1968 F100 2wd - Rangoon Red - 360 w/T18 - power steering and brakes
1997 Honda CBR 900RR
I guess it depends on the type of pump you have. My bump has a later style pump with the plastic reservoir and it is noisy with Dexron ATF but very quiet using power steering fluid. I never tried type F, though........if it calls for type F use it......I had the same thing happen......
