Installed an underhood toolbox
- Pegtop
Since there’s not a lot of storage space in our bumps, I’ve been wanting to build and install a toolbox under the hood for some time now. I came to the realization that simply bolting in a waterproof otterbox was probably the simplest way to go and would provide a weather tight seal. Bought a little vintage Ford sticker on eBay to cover up the Otterbox logo and it’s all done! Thought others might be interested and it took about 15 minutes to install.
Montreal, QC Canada
1972 F-100 Ranger 4x4 360 cid C6
1992 Mustang LX 5.0
1992 Mustang LX 5.0
Re: Installed an underhood toolbox
Nice!
Great idea. What is the part number on the Otterbox? Thank you
- Pegtop
I actually purchased a Pelican brand case on eBay. It's called a Pelican Storm case iM2075-X0000. I chose a case with no foam inside to save space but if you want it with the foam the case # is iM2075-X0001. Dimensions are 11.80" x 9.80" x 7.70" (30 x 24.9 x 19.6 cm) on the exterior and 9.50" x 7.50" x 7.25" (24.1 x 19 x 18.4 cm) on the interior. This particular one has the latches on the side and not on the front. I suppose you could get a bigger case under the hood of your truck but I found it difficult to find deep cases that were weren't completely oversized. For the install, I already had holes on the driver's side fender well from presumably a battery that used to sit there. I drilled 4 holes through the case, popped in some washers and bolts, sprayed a bit of gravel guard inside the fender well over the protruding bolts and was all done.
Montreal, QC Canada
1992 Mustang LX 5.0
1992 Mustang LX 5.0
Thanks a bunch for all of that info. It looks good and serves a good purpose!
For a very on-the-cheap version, I used an old cordless drill case that I hollowed out, used some closed-cell foam weatherstripping for a seal, and then bolted it in on the LF fenderwell. Used it for pliers, vice grips, screwdrivers, a set of HF combo wrenches, spare fuses, electrical tape and a couple extra turn signal bulbs. Picked up the case at Goodwill for $0.50, no drill included.
or, money.
or, money.
Nice mod. It's my first time to see a toolbox inside the engine bay.
