Hello Forum, I am in need of assistance on finding Hi-Performance upgrade parts for my 1967 Ford F-100 4WD.
I am currently working on my Dana 44 front axle seals replacement. Now I want to upgrade the old OEM parts to aftermarket Hi- Performance upgrades. Can anyone help me find a manufacture that makes these Hi-Performance Dana 44 Axle Tube Seals? I have been to a few sites and no experts on these inner and outer tube seals.
Thanx----
1967 F100 4WD front axle tube seals
- eggman918
Re: 1967 F100 4WD front axle tube seals
i have a national seal catalog that has many lip styles as well as different lip materials, it enables me to often find a better seal than the OEM choice that is for the same size OD/ID some times it will be thicker that OEM. But often there is room and you can double up the seals using thinner ones and in the axle application having one with the lip sealing the oil in and the second sealing the crap out is a viable option
if you have the original seal P/N a shop that carries them should be able to do the same thing for you,or you could get the catalog and do the cross reference on your own that once you have the P/N but it on Ebay
One other thing if you go the two seal route use either a design that does not have a spring or one with a stainless steel spring for the one that is facing out so it will not fail due to possible corrosion.
https://monroeseals.com/info-oil-seal-m ... -guide.php
Steve
The"Filthy Beast"- '68 F-250 Crew Cab 131"W/B 4x4 4BT compounds hx30/Wh1c,5x.012" sac injectors/ZF 5/NP203-205 /3.54 44 trutrack front/60 trutrack rear on 33's. 2nd owner
"Beauty is only skin deep....Ugly is to the bone"
It is more important to understand what you don't know than what you do know,because then you can start to learn..???
"you must deal with the attaboys and the ass chewing s with your head up and looking them in the eyes" T.J.E. aka My Dad
There are only three types of people wolves, sheepdogs, and sheep. What are you?
Thank you, I will check this out... I just logged in and sorry for late delay, been super busy... hard to find parts, greatly appreciated!!!
Parts are not difficult to find for these axles. I just rebuilt my 67 with a Dana 44 front. Torque King 4x4 has everything.
