Need front axle for 68 F100
- regreen61
Hello, I have a 1968 Ford F100 4x4 Dana44 open knuckle front axle. I am looking for the the left outer shaft. It measures 9.75, 19 spline, 1 1/4 dia, with 1 1/8 ujoint cups. New or used would be great, Thanks
68 Ford F100 4x4 / 49 Chevy PU / 51 Chevy Panel / 17 Explorer Sport / 01 Harley Road king
- Manny
Re: Need front axle for 68 F100
Welcome to fordification. I think that may match the later 78-79 axles i will check you measurements against my 79 axle i have tore down and get back to ya.regreen61 wrote:Hello, I have a 1968 Ford F100 4x4 Dana44 open knuckle front axle. I am looking for the the left outer shaft. It measures 9.75, 19 spline, 1 1/4 dia, with 1 1/8 ujoint cups. New or used would be great, Thanks
Just another Ford fool named Dan.
The Junk that hangs around
67' F-250 highboy Camper special cross breed currently under way
http://www.fordification.com/forum/view ... 22&t=86706
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
woods wrote: The rust holes in my truck were a factory install (very rare).
I have one if you're still interested.
