Fuel tank and lines
- ezmerf
Fuel tank and lines
I'm wanting to know the best way to clean my lines and tank.It's on a 72 f100 4X4 tallboy.The fuel line leaving the tank was stopped up but also have a problem it will stop getting fuel shut me down.Get out rock the truck some then I can go again until some debris blocks it.BTW I'm cheap.Merf
Re: Fuel tank and lines
You will fight this battle forever unless you pull the tank and clean or replace it. If it is plugging up with rust from inside itself then you will be time and money ahead and replace it. You have to eliminate the source.
- ezmerf
Yeah about figured that.Been given thought to putting one underneath instead of behind the seat.
