Would a 70's bed sheet be the same as a 66.
Jcreezy66
Post by Jcreezy66 »
Obviously not the outside of the boxes are going to be the same, but I was wondering if I could cut out the inside bed floor and put it in my 66? Any help will do. Thanks!
Re: Would a 70's bed sheet be the same as a 66.
Possibly but not probably. Frame mount points should be close. Inside dimensions too. I'd sketch a drawing of your bed to go shopping with. Figure out what you really need to replace and where you'd cut / weld it together to see what you need for repair panels.
66f250cs
Post by 66f250cs »
I took only a few measurements from my 66 & 69 and long beds. The 66 is loaded full of crap since I am moving to a new house TOMORROW. Yea. With a 36 x 60 shop 11 foot ceiling drywalled and lighted. As you can tell I'm jazzed. The 66 & 69; center to center on first screw directly behind bulkhead across frame is 31 3/4. Center of those screws to bulkhead is 2 plus/minus 1/8. The 69, next sets of screws towards tailgate is 31 1/2 across frame. I did not check the 66 but I think they're going to match the 69 not only across the frame but front to rear, too.
But note; the box is much closer to the cab on the 66 at 5/8" vs the 1 3/8 for the 69. Hope this helps.
66 F250 camper special
69 F250 Explorer
85 Mustang GT with 1900 original miles
92 Festiva with 538,000 original miles
86 E350 extended WB van
Various IH & JD tractors (5)
TT & XT500 mc's (6)
BSA, Triumph's and twenty Yamaha two strokes
