Jumping Speedo Needle
RangerXLTMan
Post by RangerXLTMan »
Maybe some of you guys have had this problem too. The needle on my speedometer bounces around below 40 mph then acts normal above that speed. I have changed the speedometer by putting in a spare gauge panel but the problem is the same. I was thinking of changing the gear at the transmission end of the cable next but I'm just guessing at this point. Any suggestions would be welcomed. My truck is a 1970 F100 Ranger XLT. Thanks.
WhitsEnd
Re: Jumping Speedo Needle
Post by WhitsEnd »
I have the same problem on my 1970. I installed a new cable this weekend and no change.
8) 1970 F100 Ranger 2WD
:thup: project link: http://www.fordification.com/forum/view ... 22&t=83642
Madman
Post by Madman »
I think this is very common. My old man said his did that straight from the factory.
""Never shoot a large caliber man with a small caliber bullet."
2017 Ford Raptor
1970 F250 4x4
1948 Willys CJ2A w/ Ford Flathead V-8
1975 Ford Bronco
hazelnut
Post by hazelnut »
I had one that did it years ago and pulled out the cable and wiped it with graphite, And put some graphite into the cable sleeve.
It fixed the jumping needle, I guess the cable was having a hard time turning in the casing and the graphite helped smooth it out.
Subzero
Post by Subzero »
My 72' does this, thank you for the tip. Glad it's an easy fix
1972 F100 Sport Custom-2WD, Aqua Blue and Wimbleton White, LWB, 302 V8 and C4 trans, P/S, P/B - under construction
Gone but not forgotten: 1968 F100 Ranger- 2WD, LWB, original rebuilt 360 V8, Autolite 2bbl carb, C6 Trans, Hedman Headers, Powermaster Racing Starter, H-Pipe and Glasspacks, P/S, P/B, A/C
59yblockf100
Post by 59yblockf100 »
old,we would pull the cable out wipe it down with bearing grease,reinstall it,seem to always work,sometimes the tip of the cable gets wore down,check that,speed gauge cables don't turn fast,they barely turn,
RangerXLTMan
Thanks guys for your suggestions. My truck has two cables, one from the dash that goes into a box on the firewall, and then a longer one that goes to the transmission. I guess I'll have to grease both of them and see if that does the trick.
Jacksdad
Post by Jacksdad »
Had this happen on a couple of vehicles, and pulling the speedo cable and lubing it always fixed it. It jams, winds up and then releases, hence the jumping needle. Sometimes they "chirp" when they stick too. Good luck :thup:
1971 DRW F350 cab and chassis with an Open Road motorhome conversion, Dana 70, 352 (originally 390)/C6, PS, power front discs, and 159" w/b.
