transfer case wont go into 4 low
Questions about 4WDs and related topics
59yblockf100
Post by 59yblockf100 »
I know this is for a little older trucks,but I have a 1975 f100 4x4 automatic,high works,but I cant get it to go into 4 low just grinds ,shut motor off pus it to 4 low starty it up its only in N,ANY HELP ON THIS,?????
Re: transfer case wont go into 4 low
It sounds like your linkage needs cleaning and some lube.
also make sure your cab hasn't moved around and prevents the shifter from moving all the way in.
59yblockf100
forgot to say its full time 4 wheel drive,will try cleaning and lube it,also do I have to push down on the shifter for 4 low???
Lee
Post by Lee »
You should not have to push down on the lever.
Crawl under and look at the linkage. There should be an adjusting nut on the threaded rod. When you try to put in 4L see if adjusting the linkage would allow more travel of the shift rod.
Lee
