The blower motor housing on the A/C unit in my 68 blocks the heat flow on the driver's side. What is a good unit to replace it with that wouldn't do that? If any.
Mine is a dealer add on and works well, but may replace it.
Thanks for any input.
Keep on Trucking......John
A/C suggestions
- Mancar1
- Location: USS Gramps Garage (DD-727) Tehama County, Northern Ca.
A/C suggestions
May your sails stay full, and your knots not slip. Unless a slip knot.
Once I thought I was wrong, but I was wrong.
Life is a banquet, and every days a feast.
68 F-250 CS 390 C-6 P/S A/C front disc. 2nd owner.
2016 GMC Terrain Denali 301 HP V-6 AWD.
2009 Silverado Crew Cab, V-8, 4X4.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- 1972hiboy
Re: A/C suggestions
I think it depends how deep you want to go? maybe a different evaporator head would work so you can keep all your plumbing? If you go the R134a route id recommend going new aftermarket vs refitting your R12 system. IMO it would be a better result. Do you have a pic of the evaporator head you have now?
- Mancar1
Re: A/C suggestions
When I get a pic of in cab unit I will post a pic.
Thanks 1972hiboy...keep on Trucking.......John
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- 1972hiboy
Re: A/C suggestions
I like that color. Thats weird they would have that a/c head blocking the heater so badly. I grabbed one similar out of a truck in a wrecking yard I was thinking of using in my 71 4x4 because it contours with the dash and I thought the shifter would miss it. but Ill be sure to take a good look at where it sits. If you do pull that system out keep me in mind, id be interested in buying it.
- Mancar1
Re: A/C suggestions
If I replace it I will PM you. May be a while as other stuff first.
Thanks for the reply.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
