Paint Grill
Paint Grill
Anyone ever attempted to paint a 70 f100 grill? For no more than is there there proud of the repot grills
- HIO Silver
Re: Paint Grill
The inserts or the shell???
70 F100 LB 2WD, 360FE, E-Street EFI, TKO-500, 76K original miles.. follow my rebuild: The Lo-Buck Bumpside
71 F250 LB, 2WD, 360FE, T18, PS, PB, D60 with 4.11s
73 F100 SB 4WD, 390FE, NP435, +4 on 35s
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
- Canonman67
Re: Paint Grill
I've painted the inserts with a rattle can of argent (silver) paint. I found unpainted repops for less than half the going rate of finished ones so I jumped on them. There's a picture on the last page of my build thread of you're interested. I'm planning to just clean and polish the shell.
Re: Paint Grill
The inserts are pretty simple to redo. Cleaned to death followed by some plastic primer and your choice of argent paint in light coats. The hard part is setting them aside for a month or so for the paint to harden completely.
My shell is covered in belt buckle scratches and a couple dents. I should remove the anodizing and polish it but that's a real PITA to do and then maintain.
Re: Paint Grill
The shell. Mine hasn't any debts but scratches on top part.
Re: Paint Grill
You can strip the anodizing off with easy-off oven cleaner, Spray it on and leave it on for 15-20 minutes. Wear some rubber gloves and wash off the anodizing. You may have to do it a few times to get it all off but I've done it to a few grilles and found it the easiest was so far.
- Canonman67
Re: Paint Grill
Thanks for the tip Hazelnut.
Re: Paint Grill
Your welcome
