My 68 has been so reliable for so long that when it failed to turn over, not even a click, well you all know the feeling.
Turned out all I had to do was reach down and give the n.s.s. a flick and I was off and running.
Well I know the next little thing I need to replace.
I been meaning to replace it, since my back up lights only work if I tweak the shift lever while in reverse.
Keep on Trucking.....John
no start
- Mancar1
- Location: USS Gramps Garage (DD-727) Tehama County, Northern Ca.
no start
May your sails stay full, and your knots not slip. Unless a slip knot.
Once I thought I was wrong, but I was wrong.
Life is a banquet, and every days a feast.
68 F-250 CS 390 C-6 P/S A/C front disc. 2nd owner.
2016 GMC Terrain Denali 301 HP V-6 AWD.
2009 Silverado Crew Cab, V-8, 4X4.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Re: no start
this exact thing happened to me this morning.
I was so caught up on the interwebs looking at why my back up light don't work last night. So I started flicking my NSS switch back and forth. Worked good. All the connections are there. Got some lights up out back, now I'm just missing the lever that hits the switch. This morning (sobered up) & took me a while to figure out why I had absolutely nothing with the turn of the key . But then I remembered.
- Martin Gza.
