Fuel Gauge
Southern Boy
Fuel Gauge
Post by Southern Boy »
Okay so I've put in a new fuel sending unit from LMC and my gauge now reads 3/4 full. I just put the tank back in the truck after cleaning it and put 2 gallons in it. I've read the voltage at the sending unit and it spikes up to 2.3v at the most and 0v at the lowest. I've read posts about adjusting the voltage regulator on the back of the instrument cluster but everyone posting seemed to have a full tank and reading 3/4 full. My tank is basically empty (2 gallons) and it reads 3/4 full.
What do you guys suggest I do first.
Thanks in advance.
1972 f100 360 automatic swb
Dean
Mancar1
Location: USS Gramps Garage (DD-727) Tehama County, Northern Ca.
Re: Fuel Gauge
Post by Mancar1 »
I am no expert, but I took my sending unit out and back in several times as I bent the wire a little each time. Just played with it until my gauge read right. that was a bunch of fill ups ago and everything is honky dorey now.
Some on here may say I did it wrong, but I don't care. It worked :thup:
May your sails stay full, and your knots not slip. Unless a slip knot.
Once I thought I was wrong, but I was wrong.
Life is a banquet, and every days a feast.
68 F-250 CS 390 C-6 P/S A/C front disc. 2nd owner.
2016 GMC Terrain Denali 301 HP V-6 AWD.
2009 Silverado Crew Cab, V-8, 4X4.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Southern Boy
Re: Fuel Gauge
Thanks Mancar1.
Which wire did you bend?
Mancar1
Re: Fuel Gauge
Post by Mancar1 »
I took a stick and put it in the tank it showed I had a half a tank. I then bent the rod that has the float on the end very little. I keep removing tweaking and installing the sending unit until I got 1/2 a tank reading on the gauge. did it 1/2 a dozen times until I got it. Worked for me, hope it does for you.
Keep on Trucking.....John
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
