motorcraft carburetor 2100 on 1972 F-250 360 engine
Engine, ignition, fuel, cooling, exhaust
Moderators: Ranchero50, DuckRyder
Lulu-72
Post by Lulu-72 »
Please any help would be appreciated. Can replacing accelerator pump change the carburetor settings as in idle and fuel mixture. After changing acc pump diaphragm , power valve cover gasket and base gasket has made my pickup run poorly. When driving sounds like carburetor is loading up and no power. Please advise adjustment needed. :?
Lulu-72
Re: motorcraft carburetor 2100 on 1972 F-250 360 engine
Post by Lulu-72 »
I found the problem. thanks anyway :)
HIO Silver
Post by HIO Silver »
Lulu-72 wrote:I found the problem. thanks anyway :)
And so.... what was the corrective action?
Lulu-72
Post by Lulu-72 »
When I was removing the carburetor or the choke heat tube I disturbed the fast idle adjusting screw. Since I am not well versed on carburetors I have to go slow and retain the knowledge I need to be successful, today she will purr like a kitten. :woohoo: Thanks for asking.
