sealing gas tank
Inside the cab...appearance, repair, upgrades
rwilly
sealing gas tank
Post by rwilly »
I ordered some tank sealer from Dennis Carpenter.
Think it will patch these holes?
Busboy
Re: sealing gas tank
Post by Busboy »
It might but I would always worry about springing a leak on the road somewhere. It's worth it to me to buy a new tank and have peace of mind.
rwilly
Post by rwilly »
Anybody ever use this stuff?
http://www.autozone.com/sealants-glues- ... 82799_0_0/
I think a patch on the outside, then sealer inside oughta do the trick.
rwilly
Post by rwilly »
I looked inside the tank and I am surprised on how clean it is. The pinholes are located at the bottom of the tank, below the filler hole and they are from a small amount of water sitting in the corner. I will just use the patch and call it good.
Just in case you was wondering. :wink:
BobbyFord
Post by BobbyFord »
Put a bunch of dry ice inside the tank and tig the holes.
