Well, I made a far more interesting key for my truck yesterday. I think everyone can agree that the aftermarket cut at the hardware store keys are kinda boring. My truck came with like 5 non original keys with the original set which is kinda cool because they came with the truck originally. Most people don't have originals, and those of us who do don't usually use them we use re-cuts because they are cheap. I did this with one of the five non original keys, it turned out alright.
It is rather easy to make. The tools need is a file, drill, drill bits, an a Dremel with a cut off wheel.
Obviously, you will need a hot wheels car, a key, and some JB Weld.
1.You flip the car over and drill out the rivets holding it together and pull it apart.
2. trim the key/car to fit well together, take your time you can only do this once and don't get in the way of the wheels.
3. Thoroughly, glue in the key with JB weld then put some on the rivets so it wont come apart let it cure a few hours with the key supported, you will have an awesome key.
much cooler/fun key
much cooler/fun key
'02 BMW 325xi
'69 Ford F250 C.S. Ranger 428 PI with gt 500 heads, racing c6, d60 3.73 limited slip, currently rat rod black (flat black) but going back factory Candy Apple Red / Wimbledon White
Re: much cooler/fun key
the picture is not working so here is the key.
'02 BMW 325xi
- eggman918
I like it
Steve
The"Filthy Beast"- '68 F-250 Crew Cab 131"W/B 4x4 4BT compounds hx30/Wh1c,5x.012" sac injectors/ZF 5/NP203-205 /3.54 44 trutrack front/60 trutrack rear on 33's. 2nd owner
"Beauty is only skin deep....Ugly is to the bone"
It is more important to understand what you don't know than what you do know,because then you can start to learn..???
"you must deal with the attaboys and the ass chewing s with your head up and looking them in the eyes" T.J.E. aka My Dad
There are only three types of people wolves, sheepdogs, and sheep. What are you?
- jimmy828
Now that is neat. Bet it will look even better when the truck lose's it color and gain some patina.
